FoMoCoBronCo
- Feb 20, 2023
- 61
I’m working on running new fuel lines on my carbureted ’71. I just upgraded my main tank to the 23G and my aux to NWMP’s 12G. I’ve been researching the various fuel line solutions and regardless of what you choose (OEM nylon, metal, braided, etc.), I still haven’t found a good solution to eliminate the rubber “barrier hoses” or “connector hoses” between the fuel lines and all the various barbs and nipples.
In my mind, these 5” – 10” hoses are the weak links in a fuel line system that will not only degrade within 2-5 years, but also present weak connection points for the chances of a leak.
By my count, I’ve got 11 “barrier hoses” in my OEM setup: 2 tank to fuel line hoses, 3 fuel selector switch hoses, 4 inline fuel filter hoses (1 before and 1 after the pump), 1 fuel pump to fuel line hose, and 1 fuel line to carb hose.
I’ve searched the forum extensively with no luck as to how to handle the connection points. I know they make quick connects for some of these junctions, but I have yet to find a highly-endorsed method for connecting fuel line to the metal nipples protruding from the fuel tanks, filters, pumps, and carb, without the use of a short section of rubber and a couple hose clamps.
I’m not sure if this is possible, but my initial thought has been, why don’t I heat up the end of my nylon line, then “press” it onto the barbs. When it cools, it should re-form around the nipple. I could even add a hose clamp behind the nipple end for added protection. The immediate drawback I see is the difficulty of disassembly if access is ever needed (changing fuel senders, etc.)
Can anyone provide any product recommendations, helpful threads/videos, or a review of my idea?
Thanks in advance for the help!
