I could use some help with my extended radius arm installation. I installed the BC broncos extended adjustable radius arm kit. I am having issues with the rod end binding inside the radius arm. The weld on radius arm bracket that came with the kit seems to have the wrong angle. I thought It was tight but ok. It appears that the weld on radius bracket may be designed for the stock length radius arm where the angle is greater from the bracket to the front end. See the images below. I am considering grinding a little relief into the radius arm, it looks like a little grinding could work. As well it should be noted that I had the radius arms powder coated and maybe there is simply extra material in the way and that the angle is normal. The suspension articulates fine however there is knocking sound every once in a while coming from the arms. Thank you for any help you can provide. Is grinding the answer?
