Mac2Night
- Aug 10, 2005
- 2,199
I know we are here to help old and new on CB.com, but I always seem to have the same question a hundred others before me had but mine is always somehow a different situation. Because I don’t always find the answers I need, bare with me once again.
I have a new-to-me ‘77 that has developed a stumbling idle issue that leads to it dying altogether. What happens is that it fires up first crack without feathering the pedal even. Sits there and idles beautifully for 10 minutes but then develops a stumble that gradually gets more progressive until it dies. It’s not a convulsive stumble, it’s gradual and calm, but the idle roughens until it cuts completely off. It does the same when I try to drive it.
Being a Duraspark electronic ignition, I have changed everything (wires, plugs, cap, rotor, coil, vacuum advance) including the ignition module. Checked all my vacuum ports. I changed the fuel filter and fuel pump. New gas tank and sending unit. New carb base gaskets and rebuilt carb.
Fuel, fire and air but I can’t figure it out. Ideas and opinions welcome.
