- Jun 13, 2012
- 799
morning fellas!,
project 5.0 is coming along nicely. few more questions while prior to reassembling the serp set up. i took everything off the front so i can clean and repaint.
1. what are you all doing with the EGR system? leave it or delete it?
2. Charcoal canister/Purge valve solenoid delete yes/no and why or why not?
3. while i have the serp system of the engine now is my chance to replace all the hoses. do i replace with stock rad hoses, water pump to thermostats housing etc.? basically need to know if should be picking up all stock 96 explorer hoses? i believe i have to get a reverse flow radiator correct?
one of the guys at TBP had mentioned something about the thermostat housing might need changing? not sure why it would though?
thank you in advance
