89 donor Bronco - parts to keep ?
bamabaja
The Shoals
Picked up 89 full size in running condition real cheap. Yea, I know, all addicts justify their addiction. But, my decoding (subject to being wrong- photo) shows 5.0 with AOD and 3:55 open diff. My current project is 66 U14 for road use, 351W with D30 with disc brakes. To add PS, steering column, AT (have C4), rear diff. So know AOD is “useable” but no long distance driving planned so leaning to C4. Also have several early Bronco rear axles that would be fine for my intended use. So, is 89 donor good for steering column, PS (rebuild 4x4x2), AOD better choice, rear axle and parts I’m missing useful in my project. As always, thanks for help.
sykanr0ng
steering column Maybe OK
PS (rebuild 4x4x2) Not the 4x4 but maybe the 4x2 box (those are the cheap and easy part to get)
AOD has very high overdrive, so best for highway
rear axle is an 8.8 inch which most here will tell you is a step down from the 9 inch the early Broncos came with
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Front hubs and rotors for a disc brake conversion. None of the other parts from the front end will work though.
As stated, the steering box is the much easier to find of the two boxes for the 4x4x2. You'd use the worm gear and piston out of it.
bamabaja
bamabaja
The Shoals
Thanks gents. Confirmed my inexperienced thoughts but never hurts to ask the experts. Think the 8.8 would work in my future Bronco II project but easy to find around here so may just trash on local trails. Or save 5.0 for when my truggy 5.0 dies. Thanks again.
bamabaja
bamabaja
The Shoals
Thanks gents. Confirmed my inexperienced thoughts but never hurts to ask the experts. Think the 8.8 would work in my future Bronco II project but easy to find around here so may just trash on local trails. Or pull and sell 5.0 to get my money back. Thanks again.
