I have a 76 bronco (302 C4) that is a CA original and is in the smog program I have owned it for about 6 years and I know at some point the engine was rebuilt and I am not sure if all the vacuum lines are in place and correct although it usually passes smog. It always ran ok but not perfect. I have all the 76 shop manuals and looked on line and still could not find specifics on the vacuum system. I had a few questions that I was hoping someone had some info on. I tried to explain as best I could.......
1) The ported vacuum line from the carb has a tee in it. One line goes to the distributor (my distributor only has a location for one vacuum line) and the other goes to the bottom nipple on a temp temp valve (has coolant out the top with two nipples below.) The other nipple is connected back the EGR. Does this seem correct?
2) what exactly is supposed to be connected to the air cleaner assembly? I basically have 3 different locations that have two ports a piece for a total of six. Starting at the location where the intake(air duct assembly) enters the manifold at the bottom is the first pair. One line connects to a port in the center pair(cold weather modulator). The other line is manifold vacuum (does this seem right?)
The other port in the center pair (cold weather modulator connects to a thermal switch on the air duct assembly.
The third and final set of ports has a small port on top and a large one on the bottom. The small one on top goes to the top of the bypass valve. What should be connected to the large port?
I appreciate any info or help. I just figured a good place to start was look for vacuum leaks, and try and confirm all the vacuum lines are hooked up properly. THANKS!
