My 75 seems to require excessive cranking to get started from a cold state. Once it starts it will restart with just a bump of the starter either warm or at full temperature. The ignition and wiring are mostly stock except for the addition of a Mallory Hyfire control box that was installed years ago. I had the carburetor professionally rebuilt and have set every parameter of the choke to specification. Once the engine finally fires from cold, the carburetor high idles and kicks down as it should. This leads me to believe I have an ignition issue.
I have taken some voltage readings and was hoping some members might be able to spot an errant value or point me in the direction of additional diagnostics. Here is what I have:
Battery:
Cold stored volts-12.4
Cranking volts-10.2
Running volts-13.8
Coil (positive side):
Key on/engine off-12.2v
Cranking volts-9.2v
Engine running volts-13.6v
Based on these numbers, it appears there is not a ballast resistor present which I believe is correct for a 75 Duraspark ignition. The only number that looks off to me is cranking volts. Shouldn't that be the same as battery cranking volts? If not, is 9.2v adequate for the coil?
Thanks for any help!
Battery:
Cranking volts-10.2
Running volts-13.8
Cranking volts-9.2v
