74 Bronco Front Disc Conversion Using Jeep 1979 J10
bradform
Quick question. I'm looking to do the front drum to disc upgrade on my 74 EB and have found a full Dana 44 out of a 1979 Jeep J10. I can't find any info saying parts from a 1979 J10 are compatible like the earlier 1970-1976 Dana 44's out of Chevy and Jeep donors. Any advice on the 1979 compatibility would be greatly appreciated. Thanks.
bradform
73azbronco
I'm not saying it can't be made to work, but in ten years here I've never heard of that as a "thing".
B
bradform
73azbronco. Thanks for the quick response. To be clear, I'm just looking to see if the spindles, caliper bracket, caliper, etc. from the 79 J10 will work on the disc conversion. I've found info saying the 70-76 Jeep Wagoneer is compatible, but not much on the 79 J10.
broncodriver99
Glen Allen, VA
A J10 should be a GM brake setup but they are 6 lug. I am not sure if regular chevy or ford hubs and rotors are compatible to get a 5 lug pattern.
broncodriver99
Glen Allen, VA
How cheap is the front axle? I just went and looked at the '84 J10 sitting in my yard and other than the 6 lug pattern it looks like the typical GM swap parts. If the axle is cheap or free it may be worth a shot.
B
bradform
He's asking 200 for it. From what I understand I'd need 78-79 Bronco hubs and rotors for the conversion anyway.
sykanr0ng
It might barely be worth doing if the parts were free.
For that much it would be about the same to get the 'knuckles out' from a '78-'79 Bronco or a '73-'79 F150 which would fit with a lot less trouble.
toddz69
You'll be able to use the calipers and backing plates from it and that's about it. Technically the spindles could be used too with some machining but in my mind, it's not worth the trouble to do that - just buy the correct ones. If the axle has been sitting, the calipers will need to be rebuilt.
I don't think it's worth the trouble to scrounge the few bits you can use from it.
Todd Z.
B
bradform
That's exactly the input I needed guys. Looks like a few of the kits online are on sale now. Probably better off starting with new stuff as Todd suggests. I wonder if any of these vendors have Black Friday specials? Links provided below if anyone is interested.
Wildhorses
CJPoney
Tom's Bronco
Reasonable enough. I actually prefer the Ford design anyway, but if you know what you have there should never be any issue as to what parts to order. You can even order by part number if you save them and keep them with the Bronco.
I don't really see an issue with the mixed parts as long as you know what you have.
It's a sure bet that the parts store helpers won't!;)
"Is that a full-size Bronco?"%)
