I am installing a 7 pin on a Centech harness and am in the middle of it.
I first installed a standard 4 pin by linking into the Centech harness behind the bumper. I tired a Chevy 4 pin connector first but the alignment cuts in the connector are different and I was not able to use it so I just tapped, solder and protected then wrapped the 3 wires for the 4 pin. The forth is just a local ground.
The 7 pin needs the following:
1. Right turn/brake
2. Left turn/brake
3. running lights
4. Ground
5. 12V power
6. Reverse light (optional)
7. Brake controller output
I picked up a 7 pin outlet kit that lets me plug my 4 pin into the back of it. Once I plug my 4 pin into the back of the 7 pin all I need now is to run two 14 gauge wires from the back to the front of the truck. One wire gets 12V power with a 20-amp circuit breaker. The other goes to the controller.
The Controller has its own ground, its own 12V with a breaker you need to add, the output wire running back to my bumper 7 pin, and a wire running to my tail light switch to engage when the brake lights are on.
You will also need a fuse or a circuit breaker on the 12V running directly from the Battery to the trailer.
Here is a link to a trailer site with good info:
http://www.etrailer.com/faq-wiring.aspx
