I haven't moved my starter relay yet, but this is why I have a BlueSeas fuse block hidden away, so anything that could connect to the starter relay actually connects elsewhere. Definitely helps declutter the engine compartment.
Is this what you're talking about Paul?
Yes and no. Depends on where you mount the new aux fuse panel. Where did you put yours to keep things clean?
But yes, it does get rid of that unsightly mess at the relay. Just need room for the new component.
If you change the starter to one from, say, a 96 f150 or 5.0 explorer, it has the relay built in and you can get rid of the one on the fender. Just takes a little more rewiring.
One possibility, but I would not do that. You still need the auxiliary power point, or you'll have all of the same wires cluttering up down there by the starter in the heat and oil and junk.
But more importantly the true solenoid that's on the back of that starter takes more juice to activate it than a standard Ford starter relay does, and people who've wired it like that have reported early failures of their ignition switches. Especially older ones, and newer cheap ones.
You also have the greater probability that you will get starter run-on when you release the key. It's not a universal issue, but so many people have had it happen when they eliminated the fender mounted relay that it's probably not worth the potential hassle.
Even Ford retained the old fender-mounted relay setup after switching to the new PMGR starters in the late '80's or whenever it was. Not sure about the modern cars and trucks, but they kept that scenario right up to the '01 Explorers.
The only change was the use of the newer design "pancake" style relay. Where the contact studs are vertical sticking out the top of the relay body and are typically longer too, to hold more wires.
The Explorer relay connectors are pretty cool too, and a worthwhile grab from the junkyards sometimes.
