My 351W build is coming along. 1996 van block punched .020, crank is in, pistons are in, cam is in, timing set installed. I'm now on to the timing cover and water pump which means I'm dealing with all the broken bolts and studs. 2 studs broke and one bolt.
As you look at the water pump bolt holes (with pump held up to the engine), starting at the lower left and counting clockwise, #2 (stud), #3 (bolt) and #6(stud) broke during removal.
I bought an ARP bolt kit and it has nothing useful. I also bought the Dorman/Help! water pump stud set #23744 which out of the 3 studs/bolts I needed the kit had one stud that would work, #2(stud).
#3(bolt) is easy, Lowes or HD, Tractor Supply or Ace should have what I need.
Which brings me to #6(stud). illustrated in the photo below. Which I can only fine at the Ford dealer for $22.18 each. It's the stud sticking through the A/C compressor and PS pump bracket in the 3 o'clock position on the water pump. My question is, what does that stud do? What is it's function? As far as I can tell, it does nothing but maybe "locate" the accessory bracket during install. Is there any reason I can't enlarge the hole in the bracket the stud is sticking through and use a standard bolt? Note this is a borrowed photo not of my setup.
Tim
Tim
