What application did you use for your new damper? And what is the engine out of originally?
Later model obviously, due to the serpentine belt setup. Or it could have been swapped on to the engine as well as the engine swapping into the Bronco.
Bought engine off of For Sale item here on site. Came out of a bronco in Houston and he stated it was a running 302 when he pulled it out of his bronco. I took it straight to a motor builder to rebuild and he informed me it was a 351w. Afterwards water entered one of the cylinders and busted the block. He replaced the block and it was running nicely. Suddenly the light vibration went ballistic. And I have no clue as to engine year model.
When I had a similar problem the wiring order was wrong.
A high lift 302 cam in a 351W so it needed to be the 302 firing order, not the 5.0 HO or 351W order.
So,...surprisingly it would idle okay but shake like hell at higher rpm.
But that's just my dumb luck...
