Mikes79Bronco
I bought my 71 with a 2wd steer box conversion already done to it. But whoever did it used a drop pitman arm and my draglink angles are way off, creating a lot of bump steer. I think what I need is a stock pitman arm from the F100 but no one seems to make them anymore. I ordered Proforged 103-10050 pitman arm which had some conflicting application data depending on what site you looked at it on. The splines and length were correct but the taper for the draglink was way to small. I also tried an arm from a 90s f350 which was too short and draglink hole also too small. I believe I have the wild horses drag link, not sure if that makes a difference.
https://www.wildhorses4x4.com/product/Adj_Drag_Link_P_S_F100_Kit/Custom_tie_rods#qanda
My question is does anyone know what pitman arm I am looking for and if any vendors happen to make them or if I will have to fin one in a junkyard?
