green77bronco
1990 Mustang Coupe
Original 5.0 t-5 w/77k miles. Paint 8 out of 10, Interior 9 out of 10. Fun car to drive, I just have another project I want to focus my time and money on. Everything works except the a/c, blows air just not cold. It has r12 freon in it not sure on the problem, maybe somethings clogged. I have 3 cans of r12 and some r12 oil that will go with the car. The engine was gone through about a yr ago. New rings main bearings, cam bearings. It still has the original forged pistons etc. Edelbrock performer heads, performer 2 intake, trickflow stage 2 cam, 1.7 rr, 65 mm throttle body, 75mm mass air, 24 lbs injectors, 190lph fuel pump, Mac long tube headers, Prochamber h-pipe, Mac catback exhaust, eibach pro kit springs, wilwood proportion valve, 93 cobra brake booster, sn95 brakes w/rear disk and the e-brake work. Koni adjustable shocks/struts, adjustable caster/camber plates, 17x8 billet rims w/good set of tires, 3:55 gears, rebuilt t-5 I got from the source about a yr ago, I still have the original it needs a rebuild it grinds in second gear. Zoom clutch. sct performance chip. I will add more to the list as I remember, not in a hurrry to sell so no low ballers. I also have some weld in subframe connectors and a bump steer kit that will go with the car. I know the cam is a little big for the motor, But at the time I was going to put in a nitrous kit it just never happened. I'm asking $8,500. I might take partial trade for a classic Mustang. Thanks Rick
