Revelation
- Oct 9, 2004
- 4,812
FYI FYI FYI FYI FYI
I wrote a tech article for swapping in a 1984-1991 F150/F250 Steering Column Swap ( http://classicbroncos.com/tech/1984-1991-f150f250-steering-column-swap )
The article was the swap i did on my Bronco, NOT a stock Bronco.
I am in the process of doing this swap on a stock Bronco and can say the mount for the column will not work, you must fabricate your own bracket to bolt the column to the underside of your dash, and it is a PIA. clearance on the stock gauge cluster is a major issue. As is getting the column in without removing/modifying the dash.
If I find a simple solution to the issue I will post it in the tech article.
