broncocurt
- Oct 26, 2010
- 24
Let me tell you about this AMAZING Bronco!!!! It's a 1973 Ford Bronco with a FUEL INJECTED 302 sitting on a 5 and a half full suspension lift. No body lift at all and 35 inch Mud Tires with 60% tread life. Dual exhaust with Flowmaster Mufflers. 9 inch rear with 4.56 Gears and a High pinion Dana 44 Front geared the same way. Front Disc brakes with ram assisted power steering. The brakes stop on a dime!!! There is a 6 point roll cage which is welded to the frame and brand new 4 point harness seats to keep you safe. All the equipment on the doors is brand new and everthing inside the doors works perfectly. It has a fresh coat of orange paint on the body and white on the top along with new fender flares to really make it stand out. The body of the bronco is in Great shape. I would give it a 8 out of 10 with ten being a show truck. The top on the out side is in great shape but has a little rust on the rear door. Who uses the hard top that much anyway? The floor borads are in great shape and rock solid. It has the original Ford 302 engine that has been rebuilt in the last couple years and the fuel injection system added to it. I didn't do the rebuild but trust it has been done and done right. This truck sounds amazing and runs just as good. It's a 73 Bronco so I will not guarantee the milage but they are showing 58,000. This amazing truck starts up every time with no hesitation at all and it runs and drives like a dream. All the gauges work along with the wipers and headlights. It's truely awesome to drive and be seen in. Great in the WINTER and AWESOME in the SUMMER. This is an amazing truck at an amazing price. It’s close to a show truck but still can be used as a driver. It’s an amazing driver that is a ton of fun. Call curt 773-717-2277
OTHER OPTIONS INCLUDE
POWER STEARING
DISC BRAKES
5 1/2 INCH SUSPENSION LIFT WITH EXTENDED RADIUS ARMS
FULL 6 POINT ROLL CAGE
ALL NEW SEATS AND NEW PAINT.
AND SO MUCH MORE!!!!!
Call Curt 773-717-2277
POWER STEARING
DISC BRAKES
