- Mar 1, 2013
- 373
I had a little leak in my water pump gasket that I’ve been trying to resolve. I had been making some decent progress, working on it a little each night consistently, which typically isn’t the case. I got around to pulling the water pump today and of course one of the bolts had corroded through leaving half the bolt in the plate. Around the area of this bolt is where my leak was anyways so I assume this was the main issue causing my leak. There was a decent amount of the bolt outside of the plate so I decided to try some channel lock and see if I could back it out. Instead of removing the bolt I managed to damage the area that the gasket sealing service on the plate. It’s mainly on the outside edge but I’m worried I made a smallish job into a really big job. Any guidance would be appreciated. I’m hoping that some permatex plus my gasket will be enough but I tend to be a glass is half empty kind of guy.
