- Oct 14, 2004
- 5,001
Is it just me or does everybody else have total hell everytime they tackle a project? I rebuilt a D44 with new gears and bearings and was swapping out the old D44, also adding BC Bronco's arms, Bilstein 7100 shocks, etc. at the same time.
#1 - I couldn't get the Yukon axles to fit through the knuckles without dremeling the opening some. Is this normal? I hope so...because they are in.
I took the grease fitting out of the caps, and dremeled just enough to get them in. then put the grease fittings back in. (Yukon joints)
#2 - There is not a bolt hole in the end of the axles like the stock ones. So the snap ring is basically the only thing keeping the Warn hub on there ?? Is this correct?
#3 - The BC Broncos arms are adjustable...can somebody give me a tip on eye balling the caster until I can get the front end aligned? point the yoke at the tranfer case ?? I am using the C bushings for a 3 1/2 inch lift.
#4 - My Wildhorses shock hoops have tabs to mount the shocks. The eye hole is turned wrong on my Bilsteins to use those tabs. Did I get the wrong shocks ?? I thought of drilling a hole through the hoop and using a long bolt to mount? Anybody else done that?
#5 - Ball joints. I replaced all the ball joints. I tightened the bottom as tight as I could get it. Then run the spanner down snug on top, then tightened the top nut as tight as I could...Was that the proper method? They were Moog joints and are pressed in all the way..couldn't get the snap rings on, is that normal?
Thanks in advance Guys...I'm sure I have forgot something
