Parting out a 1979 Bronco What are the good parts to keep for our early Broncos ?
Stutsmo
I am getting ready to scrap an old 1979 plow Bronco that I have sitting around. What are the good parts to keep for our early Broncos?
sykanr0ng
Steering box is the hard to find part for a 4x4x2
Front axle, rear axle are of use for 'full width' swap.
Transfer case is an NP205
Radius arms are usable.
Apogee
Radius arms
Tilt column if it has one
What engine does the '79 Bronco have? 400?
Stutsmo
Stutsmo
Do you have any idea of the value on these parts? I already sold the radius arms cause the caps had a lobe for an extra shock mount... I got $150 for the set.
sykanr0ng
Steering box $200 (at least)
Front axle, rear axle $1000 for the pair
Transfer case NP205 $200 (seen for $250 on CL)
Would be what I'd ask for from a Bronco brother, maybe more on CL.
ford man
Leesburg Ga
Does it have a brown center console in it by chance?Nice brown or red padded dash or white wagon wheels the ford factory ones with black centers?
Prizefighter
Going to echo what has been said:
Steering box!
Front and rear axles
NP205
Center console - they are hard to find
Tilt column
That's about it for our EBs. The rear tailgate should sell quickly if in good shape and the rear glass brings $50. The emblems could sell on Ebay or locally. If your interior has a cool rarer color like jade green then someone is probably looking for door panels, rear inner panels, seats, etc.
PaveBronco
X2 on all that stuff and the steering box fits in one of those 'if it fits, it ships boxes'...I say "fits" because it sort of does and you have to wrap the crap out of it with packing tape...after that...wrap it some more...
maybe wrong but intermittent wiper switch...I think?
sykanr0ng
If you don't pull the front axle the knuckles out work for a disc brake swap on the eb dana 44
You can take the knuckles out for a disk brake swap and still sell the high pinion housing too.
Rustytruck
The duraspark module, the steering column maybe the windshield washer bottle. Driveshafts if you want to chop them down. radius arms. Front coil springs if you want a stiff ass 2 inch lift.
Stutsmo
Stutsmo
Most of the interior is pretty trashed....
Stutsmo
Stutsmo
What about the front shock and spring mounts? It looks like they unbolt from the frame. I thought I remembered somebody using them on one of their builds but I don't know if it was from this year truck or not .
Stutsmo
Stutsmo
what about the steering shaft? Looks like the length is adjustable would it work in an EB?
sykanr0ng
It can be, depends on what steering box you use.
4x4x2 yes.
Original no, the spline count and size are wrong.
Not sure about others.
sykanr0ng
There is an F250 mount that gets used, don't know about the big Bronco/F150 mount.
