Made some wire-plan and test progress. What I absolutely do NOT want is multiple sensors doing the exact same thing. It's messy, I don't like it. I also don't like excessive and useless wires. So, that mean doing things my way, from scratch. I had to wait a long time for that Telorvek panel to make "my way" easier and then I got the Stinger extension harness for my COP and cam sync and crank trigger setup, that was sooo nicely wrapped and of course, I had to un-wrap that all, so fun!
I've been planning my integration of VSS, Coolant Temp, Oil Pressure (since I want my ecu to have that info as well as I can set rules) and today it was time to see if I could make those all work nicely together and see the same info on both my Dakota Digital as well as the ecu.
I tried reading a bunch of thread on the VSS and seems like everyone had a different answer, none of which worked for me. I decided to try running the Dakota Digital pulse generator and then just splice into that and give the ecu the same parameters that DD is using and it looks like it worked perfectly (tested with a drill).
I had a weird experience with the Dakota Digital Oil Pressure sender when I had it connected to the ecu and then the data relayed through the BIM to the Dakota. It gave a crazy high reading while sitting on the floor and then even disconnected it was giving me 30 lbs or so. Not sure what the deal is, but connected it the right way to the DD box and then just spliced the signal line into the ecu and works great (I think--I'll know for sure when I run it for real but should be good).
Stock ford temp sender was easy and info relays easily to the DD, but I might try the DD one anyway since it's new and nice but not sure yet.
Also tested the fuel level sender and works fine.
These things took time and made a mess but wasn't as painful as it could've been!
The other issue, since I think I have more stuff to hide than most has been where to put it. The man, Dan Carr of Carrparts, who so perfectly built my dream console was tasked with another request from me and he seems to have nailed that one as well.
All I did was dream it up, hopefully my dreams fit, but I asked him to make me these boxes for the kick panels. One on each side…one side will have the Telorvek panel And the other will have the Bronco panel and then a battery buss bar and other stuff.
He just finished then and hopefully I didn’t mess up my measurements and they fit as planned!!!
I’ll cut, test fit, cut wiring holes, and then powdercoat before final assembly. Wish me luck.
