DanWheeler
Just wanted to get a quick sanity check on my plan. Right now I have the Wild Horses track bar riser which is incompatible with the BC Broncos Wristed Axle Housing.
I could probably cut back the WH track bar riser to make the WAH fit but I dont feel good about modifying such an important part.
My thinking is to cut off the WH riser completely as well as the stock track bar mount and install the Ballistic Fabrication track bar mount:
http://www.ballisticfabrication.com/Panhard-Trackbar-mount_p_1399.html
which should leave plenty of room for the BC Broncos WAH.
Then I would just need to figure out the track bar situation w/ Rod end on one side and bushing on the frame side. I know BCB sells a track bar like that but I'm not sure the dimensions are right. I'll probably just fab up my own.
sound like a plan? Am I forgetting about anything?
