... Ok this is not AC on my Bronco ..But it's a general Question that may help someone working on their Bronco.
I've bought this old Dodge truck, That like a lot of our BRONCOS it'd been setting for several years. SO after getting it home & New plugs & a service job new battery .. It cranked up & is Running remarkable well. SO I drove it & it feels really good in the steering. SO I got to thinking Since it has a Wrecker Bed ''WESTERN HAULER BED'' With a goose neck ball & I might could use it to pull my Bronco around.
SO I noticed the Blower for the AC is working like it should .
But no Cold AC .. So I jumpered the Ac pressure switch . Clutch on the Compressor popped on.
... So I got a can of Freon from my shelf . It was one of those new cans that has the valve & gauge in the hose.
The truck took what was left in the can .. Maybe 1/2 a can. & Pressure was on 30lb. That's a good pressure figure.
... So I went to Walmart & picked up 3 more cans of freon R134. Home & had a little trouble getting the 1st can to work .The 1st valve broke & SO I went back to O'Reilly's & got a metal tap with a gauge in it's line .
Home & I installed another can of 134.. Still no COLD AIR.
.. I took the jumper out clutch cut out . SO I put the jumper back in.
put in another can of R134 ...So 2 plus cans of freon .. But not a hint of Cold Air . Pressure is at about 35lbs.
I can't check the highside.
I used to have real gauges but they got so old I put them down & into the burn barrel not long back.
... SO Anyone want to say why I have no Cold Air. if the low side is that good of pressure.
..... It does have the Sight Glass in the top of the dryer .. It seems to be 98% free of bubbles .
It's has a Expansion Block. those cause lots of troubles.
...ANY THOUGHT of what to check next.
....Oh & the truck ran for like 30 minutes idling & It never got hot . It stayed at 195 on it's after market gauge, So I'll say the Condenser is not bad.
