Tell_Sackett
First a little background. I picked up my first EB just before Christmas after looking for around a year. When I got it home and took it for a spin the problems started to show up. Tie-rod ends shot, carb a little gummed up, 2nd gear syncro barks when down shifting as well as the charging system not working. I got most of that worked out when a rod knock started to develop. Pulled the engine and sure enough, the rod bearings were shot. So with that and the cylinder walls showing some wear, I decided to just leave it out and rebuild/fuel inject it. Which brings me to my q's.
I have located a 93 (i think) bronco that has been totaled, (actually, upside down in a canyon for at least the last 10 years) with a 351w in it. The story is that it rolled down there as a brand new car. I am still trying to track the property owner down to try and get permission to drag it out but think that it would make a good block to work with. I know that the intake is going to be too tall, but BC makes the adapter to use a truck lower and car upper. What else off of this could I use? I think the fuel rail would work as well as the ignition system maybe? What about the ECU?
I am on a limited budget but if this works then I am hoping I can get the truck for free. What else would I need?
Thanks for any help
Thanks for any help
