Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 11/08/17, 06:38 PM   #1
1buckeyefan1
Columbus, OH
74 EB Explorer - The "Great Pumpkin" Newbie Build
Hi y'all. I'm a newbie Bronco owner, proud nth? owner of a 1974 U15 Explorer. Haven't pulled a Marti report or anything yet, but am staring at my winter project.
I've been consuming as much knowledge as possible the last 2 months from this forum. great stuff. I find myself checking daily, craving new build threads while digging up old ones that are relevant.
So I decided to start my own thread.. mainly for selfish reasons to get some sage guidance on how far to take the "Great Pumpkin". My late father owned a 1976 EB rust bucket, tore it down and tinkered with it for 10+yrs and unfortunately passed away before he could finish it. The family finished it and we still have it, hence my itch to pick one up, but not leave it in parts for years before I get to enjoy it.
I scored The Pumpkin locally, and it has had a few resto-mod improvements from the PO's through the years. I'm partial to keeping it this way but getting it rust & dent-free w/ some fresh paint, semi-restomod, keeping front/rear cut w/ some warflares, etc. Some decent upgrades:
  • Painless Wiring Harness
    Flaming River Steering column
    Front disc brake conversion
    Rampage soft top (no hard top included)
    15" wheels w/ 33" BFG tires
    Edelbrock intake and carb (I just recently rebuilt it..running much better after sitting for 2yrs)
    Beefy rear bumper w/ tire rack and jerry can holder
    Roll cage
So while I crave a full frame-off resto, i'm afraid of it sitting for years and costing 5x my budget. I've got a heated shop, welder, tools, and some basic welding experience. I have access to a lift and am strongly considering taking the body off to thoroughly clean & POR15 the frame, clean/paint the engine, replace lines, etc
Where I struggle (for now) is how far to take the body panels. ie, replace or repair? Here is where I could use the most guidance on where to get them to good driver quality before I have a paint/body guy tackle it.
I'll start with some pictures and follow up with a few chaser posts.
Click image for larger version
Name:	1974 bronco polished.jpg
ID:	434454   Click image for larger version
Name:	drivers angle.jpg
ID:	434455   Click image for larger version
Name:	drivers front angle.jpg
ID:	434456   Click image for larger version
Name:	drivers quarter.jpg
Name:	drivers rear bent 2.jpg
ID:	434458   Click image for larger version
ID:	434459   Click image for larger version
ID:	434460   Click image for larger version
ID:	434462   Click image for larger version
ID:	434463   Click image for larger version
ID:	434464   Click image for larger version
1buckeyefan1 is offline   Reply With Quote
Old 11/08/17, 06:53 PM   #2
1buckeyefan1
Columbus, OH
Rust repair vs. replace?
Here is where I struggle as I'm compiling my "black friday purchase frenzy". Which panels should I attempt to patch & repair vs. buying repo from JBG? I'm in driving distance and plan to make a trip up there on Black Friday to hit JBG and a few other stops along the way.
The easiest way is to probably post all of the rust pics and my thoughts.. would appreciate any/all feedback:
All: has the Explorer trim holes that I plan to delete/weld closed.
Driver's door: drivers has typical rust holes in the bottom and outside had towing mirrors and appears to have been beaten with a baseball bat I'm looking to probably just find a nice donor door vs. repairing + reskinning
Passenger door: has tow mirror holes and mud. who knows what else. May find a matching set of donor doors vs. skinning
Passenger quarter: my biggest dilemma. Has a bit of rust-through at the inner/lower seam, but rest is mostly solid. So I go through the effort of replacing both or find a way to cut out the seam and use a patch panel in the seam?
Tailgate posts: drivers is pretty well bent, passenger has spare tire holes + mud. Will probably just replace w/ repo?
Fenders: drivers took a beating too and has some surface rust at the bottom. debating if worth knocking the dents out vs. replacing w/ repop? I'll probably end up cutting the new ones anyhow
Hood: has a stress crack on passenger side and mud. will probably find a better donor
Passenger inner fender wall: has a large area where essentially delaminating a layer of metal? Cut/patch this area vs. replace panel?
Floors: fronts have been replaced by PO, rears have some small areas that I think I can simply cut/weld the gaps.
Tailgate: appears solid, will probably weld/delete the spare tire and trim holes.
Passenger door sill: has pinholes that I can probably / hopefully weld.
Drivers lower/outer door post cover: has a good size hole. I'm probably just going to order this from JBG and replace it.
This is where I could use alot of help.. on where to take the above? Sorry for the long-winded post. Appreciate any/all feedback!
Name:	drivers door mirror.jpg
ID:	434466   Click image for larger version
Name:	drivers door post.jpg
ID:	434467   Click image for larger version
Name:	drivers door rust 2.jpg
ID:	434468   Click image for larger version
Name:	drivers door rust.jpg
Name:	front apron.jpg
ID:	434470   Click image for larger version
Name:	drivers rear bent.jpg
ID:	434471   Click image for larger version
ID:	434472   Click image for larger version
Name:	passenger door bondo.jpg
Name:	passenger rear rust.jpg
ID:	434474   Click image for larger version
Name:	passenger door rust.jpg
ID:	434475   Click image for larger version
Name:	rear floor rust.jpg
Old 11/08/17, 08:21 PM   #3
Mac2Night
Mac2Night's Avatar
God, Country, Family, Broncos..... not always in that order
Atlanta/Decatur
Nice score and welcome to the Board! You actually have a 1973 Burnt Orange on orange interior Explorer. This was a '73 year only package (also came in Grabber Blue on blue interior) that year only. Here are some photos of my '73 Explorer... you might notice some similarities
I say you are on the right track to get a Marti report, it will confirm exactly what options yours came with.
ID:	434484   Click image for larger version
ID:	434485   Click image for larger version
Name:	Screen Shot 2017-04-17 at 10.43.10   AM.jpg
ID:	434486   Click image for larger version
Name:	Screen Shot 2017-06-01 at 12.42.31   PM.jpg
'73, 302, uncut Bronco Explorer, Burnt Orange
'69, 302, uncut, one owner, Reef Aqua
'74 Sport, Midnight Blue Metallic, 302, 3spd, uncut
'73 Base, 302, uncut, one owner, Winter Green
Mac2Night is offline   Reply With Quote
Old 11/08/17, 09:12 PM   #4
1buckeyefan1
Columbus, OH
Hmm, interesting. According to my vin tag it was a S23044, which according to the Broncohio decoder makes it a late (July) 1973. How accurate is the decoder and is there any chance Ford called the last batches 1974?
btw, thanks for sharing the pictures. It's interesting to see what it originally looked like. Yours is in amazing condition.. I really dig the original seats..I can't fathom how to get something in that pattern reproduced in order to return mine to it's original glory
Old 11/08/17, 09:48 PM   #5
Mac2Night
Mac2Night's Avatar
Atlanta/Decatur
Others can certainly chime in on the VIN sequences but as I said, the Marti report will confirm what it is. Here is the '73 Explorer brochure for some reference material:
Name:	Screen Shot 2017-11-08 at 10.32.29 PM.jpg
ID:	434497   Click image for larger version
Name:	Screen Shot 2017-11-08 at 10.33.00 PM.jpg
Old 11/08/17, 09:54 PM   #6
TX SS
TX SS's Avatar
Houston, TX
Bronco Hut is your source for original style seat covers.
https://broncohut.com/products/explo...t-covers-front
1973 Sequoia Brown
TX SS is offline   Reply With Quote
Old 11/09/17, 06:06 AM   #7
JGbronc
Bronco Maniac
JGbronc's Avatar
3rd generation of Bronco owners. It's the first two's fault.
Hytop, Alabama
eBay: j77bronco
Welcome to CB! Nice find, I love that color!
It is indeed a '73 like Mac said. That VIN decoder is close, but not always completely accurate. However yours is correct. You have a late '73.
I second the Bronco Hut recommendation.
'66 U13
'67 Military
'71 Sport (Wifey's)
'76 Explorer
JGbronc is offline   Reply With Quote
Old 11/09/17, 08:06 AM   #8
half cab
equestrian patcher
half cab's Avatar
ride like the wind bullseye
ms
I believe Aug. '73 would have began the '74 year models. I say that but I know of a '77 built in July '76. Build date that was built same month as my '76.
76 SPORT 351W C4 PDB
half cab is offline   Reply With Quote
Old 11/09/17, 08:11 AM   #9
1strodeo
U15 Apprentice
1strodeo's Avatar
Fix,Drive,Modify,Repeat
Centerville, OH
"Orange or Blue instrument panel" does that mean the dash was painted body color instead of gray?
1966 LUBR, 170 3spd, 2.5" SL, 1" BL, 31x10.5x15 on steelies (tub under construction 3/2017-present) Tonko
1972 U15, '68 302 3spd, 2.5" SL, 1" BL, 35x12.50x15 on 94 Bronco wheels, neighborhood driver Frankie
I got a fever...and the only cure...is more Bronco
1strodeo is offline   Reply With Quote
Old 11/09/17, 08:15 AM   #10
bchesley
bchesley's Avatar
Whitehouse, Texas
I have a set of the Bronco Hut seat covers. They are top notch. I just picked up a new 72 explorer and will be ordering a set for it also. You will not be disappointed. In that photo I had just finished installing the skins. A few days in the sun removed the wrinkles. They look perfect now.
1975 Money pit named "Trigger" 5.5 WH lift with Duff Long Arms, 35" MTR, BC Soft Top, Baillie cage, 4.56 Gears, Locked, 1-ton steering, PSC Box
1972 Bronco Explorer/Sport, Candy Apple Red, Ginger Explorer Interior, All stock
bchesley is offline   Reply With Quote
Old 11/09/17, 09:06 AM   #11
JGbronc
Bronco Maniac
JGbronc's Avatar
Hytop, Alabama
eBay: j77bronco
Yes, but in '73 the standard dash color was parchment. Rangers and Explorers had body color dashes with the exception of the '72 Explorer/Sport.
'66 U13
'67 Military
'71 Sport (Wifey's)
'76 Explorer
Old 11/09/17, 09:56 AM   #12
mlarison
Palm Coast
Huge fan of BroncoHut for seat covers, I used them for my 74 Explorer and they came out great!! Melissa is really great to deal w/ too!!
1974 Blue/Blue Explorer 2.5 lift uncut
mlarison is offline   Reply With Quote
Old 11/09/17, 12:14 PM   #13
1buckeyefan1
Columbus, OH
Are those the same orange covers? I like the tannish tint to them? I saw them on another wood-themed post some time back and assumed they were custom?
Sent from my Pixel using Tapatalk
Old 11/09/17, 06:33 PM   #14
bchesley
bchesley's Avatar
Whitehouse, Texas
No they are ginger outer with the orange center cloth. I just loved the pattern. My 75 was not an explorer, but it has killer seats now.
Old 11/09/17, 06:47 PM   #15
WILDHORSES
WILDHORSES's Avatar
Lodi CA
Here's some pretty recent shots of BHut's legit Explorer upholstery. In a 73 we have. Matched the stock rear seat perfectly.
Jim
ID:	434554   Click image for larger version
WILDHORSES is offline   Reply With Quote
Page generated in 0.35203 seconds with 59 queries
