77RHINO
- Feb 22, 2011
- 308
I finally pulled the motor out this weekend to open it up and see what has been causing all my oil consumption. At first glance, the only thing I noticed was that one rocker was loose/off the valve a little bit but not enough to damage the valve or rocker arm. I went ahead and took the heads off, cleaned everything up, lapped the valves and put in new valve stem seals. The originals didn't seem to be in bad shape like I thought (2 years old). As the pics below show, there was alot more sludge/carbon buildup on the intake valves than I was expecting to see. It looks there was enough on there to not allow the valves to close properly, and you can see oil/fuel leaking out from under the intake valve in one of the pics. What do yall think is causing this? What else do I need to be looking for with the heads off?
