77RHINO
- Feb 22, 2011
- 308
A little background before the technical questions:
This past weekend I took my Bronco on a trip from Birmingham down south of Jackson, MS. Not too far of a trip (260 miles each way) and knowing my tricky fuel gauge, I stopped every 100 miles for fuel. I got a fresh oil change (put in 5.5 qts) immediately before jumping on the interstate, and got going. The engine purrs about 2700 rpm at 70 MPH, and has a TON of torque to accelerate in 5th to pass and whatnot ;D When I hit the first 100 miles, I stopped and gassed up (13mpg) and checked the oil. I needed 2 quarts to get back up to full!! I put that in, bought some more for the road, and took off. 2nd stop, I pulled off, and the brakes hit the floor, nothing. Get off into a gas station and look underneath, brake fluid pouring down from above the rear diff. I guess the vibration rubbed a hole at where that brake line clip sits on top of the diff. Got the vice grips, krimped the line 6-7 times and pinched off flow to the back right wheel, added fluid, and then checked the oil. LOW AGAIN Added 2 more quarts, and took off. Made it to the farm and parked it for the night, needed about a quart when I got there. Repaired the brake line Saturday, drove it around the farm sat night, and then loaded the gear back up and came back on Sunday, using a quart of Marvel Mystery Oil, a bottle of Lucas Oil Stabilizer (Emergency kit stuff) and also used 3 quarts of oil. I had a blast driving it, but will need to look into some better seats and another gearset, that one is entirely too loud!
Now, what are all the possibilities for burning that much oil?
It dripped about 3 drops while parked overnight.
No oil sheen underneath the bronco.
No shortage of torque/horsepower
I know I am burning it, blue smoke at startup
blue smoke if I hammer the throttle
Coolant looks good and green
When idling, you can barely see puffs of smoke out of the pipe if the sun hits it right.
Oil pressure never dropped below 40, stayed just under 70
New PCV, but I do notice the line to the carb seems to "sweat"
Do all these symptoms point to bad valve guides/stem seals?
