Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 01/19/17, 08:53 PM   #61
BajaBronco
BajaBronco's Avatar
Collect Them All! (some vehicles not for use with some sets.)
Petaluma, CA
forgot you're running a toploader. I made my own linkage and brackets for it, but I see you've reinforced yours to be strong. Is that advance stuff. I repopped what Duff and Stroppe built. I may send you a set to mock up when you have time and can pack as a spare linkage..... unless you have duplicates of what you already have. The old Duff and Stroppe are really strong.
www.BajaBronco.com
'69 Stroppe Bronco Racer "Blue Torch" Kaysinger Racing
'66 Stroppe Racer Minor/Bayer/Unser/Jones #3
'68 Stroppe Racer: Rod Hall's former truck
'72 Baja Bronco "Tampico" yellow
'72 Baja Bronco
'68 Kit Baja U14
'71 Bronco wagon project
BajaBronco is offline   Reply With Quote
Old 01/20/17, 07:58 PM   #62
Swerve
Swerve's Avatar
Naples, Maine
The brackets are a combination of Tom's three speed and home fabricated...I sent a pm about linkage...
Swerve is offline   Reply With Quote
Old 01/22/17, 05:05 PM   #63
Swerve
Swerve's Avatar
Naples, Maine
Made the two panels that go between the rockers and frame. Mounted the front bump stops. Installed the steering dampner bracket. Started sorting out my rear brakes with the Warn full float kit. I plan on flipping it right side up next weekend...
Click image for larger version
ID:	411533   Click image for larger version
ID:	411534   Click image for larger version
ID:	411535   Click image for larger version
Old 01/29/17, 05:32 PM   #64
Swerve
Swerve's Avatar
Naples, Maine
More grinding, welding and some paint...at least all of the areas easily reached while it is upside down. Tomorrow evening it will be right side up, gotta wait for the paint to dry or it would be topside already.
Also filled in the holes on my rear backing plates and drilled them to fit my housing ends.
ID:	412167   Click image for larger version
ID:	412168   Click image for larger version
Old 01/31/17, 07:13 PM   #65
Swerve
Swerve's Avatar
Naples, Maine
Finally, it is right side up again...
ID:	412231   Click image for larger version
ID:	412232   Click image for larger version
Old 02/01/17, 10:07 AM   #66
House
House's Avatar
Minutia Militia
Looking good!
______
|_____|
(o===o)
||---o-||
House is offline   Reply With Quote
Old 02/01/17, 11:04 AM   #67
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
KEEP it going Dave!
tasker is offline   Reply With Quote
Old 02/01/17, 12:45 PM   #68
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Nice work, Lots of it too. Keep it up
sprdv1 is offline   Reply With Quote
Old 02/01/17, 03:55 PM   #69
Swerve
Swerve's Avatar
Naples, Maine
Thanks all!...I appreciate the encouragement
Old 02/05/17, 05:57 PM   #70
Swerve
Swerve's Avatar
Naples, Maine
Today was a productive day!
First, I installed my custom shackles by Migs. Then I installed my leaf springs. A porta power and floor jack make this easy work for just one person.
Next, I installed my NASCAR style inner axle seals in my rear housing. These seals should stop the leak problems associated with the Warn full float kit.
Then I installed my carrier. It is a Mosher Wavetrac, 4:88 to 1. Damn is that rear end heavy. I wound up using a come along attached to my ceiling just to get it from my bench to the floor.
ID:	412644   Click image for larger version
ID:	412645   Click image for larger version
ID:	412646   Click image for larger version
ID:	412648   Click image for larger version
ID:	412649   Click image for larger version
ID:	412650   Click image for larger version
Old 02/05/17, 05:58 PM   #71
Swerve
Swerve's Avatar
Naples, Maine
Then I installed my rear axle. I bolted my Warn spindles and hubs on, no outer seals yet, and put the tires on...
Next I installed my Wrap trap. It is just tacked in for now. I shortened it to fit between the frame rails. I need to put some weight on the back to try and get the angle correct.
Installed rear bump stops.
ID:	412653   Click image for larger version
ID:	412654   Click image for larger version
ID:	412655   Click image for larger version
ID:	412657   Click image for larger version
ID:	412658   Click image for larger version
ID:	412660   Click image for larger version
ID:	412662   Click image for larger version
Old 02/05/17, 06:01 PM   #72
fatboy
Glad to be here.
fatboy's Avatar
Bad decisions make for good stories.
Coastal NH
Brian (aka migs) sure does make some nice stuff!
Life's a Journey Not a Guided Tour.
Good judgment comes from experience. Experience comes from poor judgment.
The Mutt
Village Idiot Build
fatboy is offline   Reply With Quote
Old 02/05/17, 06:06 PM   #73
Swerve
Swerve's Avatar
Naples, Maine
Yes, he does!
Installed my Beard seats so I can figure out where to weld my mounts for the five point harnesses.
Got a little more paint on the front.
ID:	412664   Click image for larger version
ID:	412665   Click image for larger version
ID:	412666   Click image for larger version
Old 02/06/17, 09:08 AM   #74
phred
phred's Avatar
"can't you say something righteous and hopeful for a change"
atlanta
eBay: brizance
Love the progress.
phred is offline   Reply With Quote
Old 02/06/17, 09:16 AM   #75
69broncofun
69broncofun's Avatar
“We can’t help everyone, but everyone can help someone!”
DFW
Originally Posted by Swerve View Post
Yes, he does!
Looking good. Boy you sure do have a lot of model kits.
69broncofun is offline   Reply With Quote
Page generated in 0.35656 seconds with 54 queries
