Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 12/06/16, 06:08 PM   #46
toddz69
Phoenix/Prescott, AZ
Glad to hear you're collecting is going well! My box also has a set of caliper brackets in it too.
Todd Z.
Todd Zuercher
69 Bronco and half of a Stroppe Baja racing Bronco
toddz69 is offline   Reply With Quote
Old 12/10/16, 10:58 AM   #47
Swerve
Swerve's Avatar
Naples, Maine
Todd Z.
Yes, found the brackets as well, thanks!
Swerve is offline   Reply With Quote
Old 12/10/16, 11:06 AM   #48
Swerve
Swerve's Avatar
Naples, Maine
More parts gathering;
Received my front hubs / rotors from toddz69.
4x4x2 power steering box from BC Broncos.
Currie RockJock high pinion Dana 44 front axle.
Crane inner C's (no photo).
Click image for larger version
ID:	408900   Click image for larger version
ID:	408901   Click image for larger version
Old 12/17/16, 05:00 PM   #49
Swerve
Swerve's Avatar
Naples, Maine
Between work being very busy, helping with my wife's health issues, and the damn cold and snow I have not been able to make any sparks fly recently...but I have been able to gather some more parts...
Picked up a nice used MSD (came from a NASCAR race car) ignition set up. Dual pick up billet distributor, GM switch to run two MSD boxes, dual coil set up, rev limiter, wider cap, harness pieces...
New power steering pump from BC Broncos.
Ford Motorsports valve covers.
Rear axle bump stops. I will need to modify the mounts a little but they will fit / work well for my application.
Fiberglass hood.
ID:	409292   Click image for larger version
ID:	409293   Click image for larger version
ID:	409294   Click image for larger version
Old 12/23/16, 06:20 PM   #50
Swerve
Swerve's Avatar
Naples, Maine
I checked in on my engine at the machine shop yesterday. Main cap studs installed, and it has been align honed. The stroker kit has been ordered.
Also picked up more parts. Crane inner knuckles and Reid Racing knuckles.
ID:	409579   Click image for larger version
ID:	409580   Click image for larger version
Old 01/07/17, 08:16 AM   #51
Swerve
Swerve's Avatar
Naples, Maine
My rear axle housing came back from it's final welding at John's Industries.
More parts gathering and more welding and grinding on frame and skid plates.
Had my Australian Cleveland 2v heads CC'd. So will go with flat top pistons that will give approx 10.5 to 1 compression ratio.
I will post more photos this evening...
ID:	410594   Click image for larger version
Old 01/08/17, 05:43 PM   #52
Swerve
Swerve's Avatar
Naples, Maine
Rear leaf spring mounts and shackle mounts are reinforced. Rear skid plate welded in place. Nice to be able to start putting paint (POR-15) to it...Got a coat of paint on my rear axle housing as well...
ID:	410662   Click image for larger version
ID:	410663   Click image for larger version
Old 01/08/17, 06:18 PM   #53
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
mighty impressive Dave!
tasker is offline   Reply With Quote
Old 01/08/17, 06:32 PM   #54
Swerve
Swerve's Avatar
Naples, Maine
Thanks Randy!...See you Tuesday evening...
Old 01/11/17, 06:57 AM   #55
Swerve
Swerve's Avatar
Naples, Maine
Picked up a nice pair of fiberglass fenders from Tasker...
ID:	410835   Click image for larger version
Old 01/11/17, 07:18 AM   #56
tasker
tasker's Avatar
The granite state
make us all proud Dave!
Old 01/12/17, 06:40 AM   #57
Mountain Ram
Recovering Masshole
Mountain Ram's Avatar
Abingdon, VA
Great thread... Cant wait to see how it turns out and how the trip goes- Sub'd!
First Class Hack
Mountain Ram is offline   Reply With Quote
Old 01/15/17, 05:36 PM   #58
Swerve
Swerve's Avatar
Naples, Maine
Weld, grind, repeat...Started on the center skid plate / pan. It is held on with four countersunk screws. Will close up the area between the inner rockers and frame next. Boxed my motor mounts. Closed off the area between the front cross member and the front bumper reinforcement. Lengthened the slots on the transmission / transfer cross-member mounts to compensate for the longer four speed transmission.
ID:	411105   Click image for larger version
ID:	411106   Click image for larger version
Old 01/16/17, 09:15 AM   #59
tasker
tasker's Avatar
The granite state
so cool, let me know when you want to "pre run" up here!
Old 01/19/17, 07:40 PM   #60
Swerve
Swerve's Avatar
Naples, Maine
Looking forward to it tasker!
Today I got home from work a little early, so I had the opportunity to finish up my rear bump stops. They are from a Nissan Pathfinder. I needed to cut and bend the mounts to make them sit level / horizontal...
I hope to have the truck right side up again this weekend...
ID:	411392   Click image for larger version
ID:	411393   Click image for larger version
ID:	411394   Click image for larger version
ID:	411396   Click image for larger version
ID:	411397   Click image for larger version
ID:	411398   Click image for larger version
Page generated in 0.44270 seconds with 60 queries
