Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 10/29/16, 09:28 AM   #16
Swerve
Swerve's Avatar
Naples, Maine
Mocked up seating and steering...
Click image for larger version
Name:	Bronco Seats Steering Column Wash Bag Dash Pad 004.jpg
ID:	406163   Click image for larger version
Name:	Bronco Seats Steering Column Wash Bag Dash Pad 005.jpg
ID:	406164   Click image for larger version
Name:	Bronco Seats Steering Column Wash Bag Dash Pad 002.jpg
Swerve is offline   Reply With Quote
Old 10/29/16, 09:30 AM   #17
Swerve
Swerve's Avatar
Naples, Maine
Re-conditioned the speedometer...and new intake manifold
ID:	406166   Click image for larger version
Name:	Rolling Pin 040.jpg
Old 10/29/16, 09:35 AM   #18
Swerve
Swerve's Avatar
Naples, Maine
Modified a '66 dash I had to replace the sorry original. Moved the glove box door over to clear the cage.
Name:	Bronco dash 32 doors 016.jpg
ID:	406167   Click image for larger version
Name:	More Stuff 048.jpg
ID:	406168   Click image for larger version
Name:	More Stuff 053.jpg
Old 10/29/16, 09:45 AM   #19
Swerve
Swerve's Avatar
Naples, Maine
I had knee surgery the end of 2015 so I mocked up some panels for inspiration...
Name:	Bronco Panel Mock Up 015.jpg
ID:	406170   Click image for larger version
Name:	Bronco Panel Mock Up 016.jpg
Old 10/29/16, 09:49 AM   #20
Swerve
Swerve's Avatar
Naples, Maine
Picked up a pair of fiberglass doors here on CB that we will use if we get too close to maximum weight for class, 4000 lbs.
Name:	Bronco Fiberglass Doors 001.jpg
ID:	406172   Click image for larger version
Name:	Bronco Fiberglass Doors 002.jpg
Old 10/29/16, 09:55 AM   #21
Swerve
Swerve's Avatar
Naples, Maine
Test fitted Wild Horses 5 1/2" lift rear springs...A Porta-Power makes this easy work! Custom shackles by Migs...
ID:	406174   Click image for larger version
Old 10/29/16, 10:03 AM   #22
BajaBronco
BajaBronco's Avatar
Collect Them All! (some vehicles not for use with some sets.)
Petaluma, CA
So great, Swerve! I got your cactus smasher - just finished re-tooling and first batch done soon.
www.BajaBronco.com
'69 Stroppe Bronco Racer "Blue Torch" Kaysinger Racing
'66 Stroppe Racer Minor/Bayer/Unser/Jones #3
'68 Stroppe Racer: Rod Hall's former truck
'72 Baja Bronco "Tampico" yellow
'72 Baja Bronco
'68 Kit Baja U14
'71 Sport Kit Baja, Poppy Red
'71 Bronco wagon project
BajaBronco is offline   Reply With Quote
Old 10/29/16, 10:06 AM   #23
Swerve
Swerve's Avatar
Naples, Maine
Thanks! I think it will be a nice, nostalgic touch...
Wild Horses Wrap Trap brackets welded on rear axle housing...Rear axle housing is by John's Industries. Their center section is made from 1/4" steel, axle tubes are 3/8". Mosher 31 spline 4:88 Wavetrac waiting for install. Also using the Warn full float kit. I will be running NASCAR style inner seals at the carrier (along with the seals Warn provides at the outer) to hopefully stop any leaks.
ID:	406176   Click image for larger version
ID:	406177   Click image for larger version
ID:	406178   Click image for larger version
Old 10/29/16, 10:24 AM   #24
Swerve
Swerve's Avatar
Naples, Maine
Started fitting the Ruff Stuff truss...Also picked up a pinion guard...
ID:	406185   Click image for larger version
ID:	406186   Click image for larger version
ID:	406187   Click image for larger version
Old 10/29/16, 10:27 AM   #25
Swerve
Swerve's Avatar
Naples, Maine
Found a good deal on a new set of James Duff radius arms on ebay, and a breather kit on craigslist...
ID:	406190   Click image for larger version
Old 10/29/16, 10:31 AM   #26
Swerve
Swerve's Avatar
Naples, Maine
Started fitting inner cab sheet metal...
ID:	406192   Click image for larger version
ID:	406193   Click image for larger version
Old 10/29/16, 10:34 AM   #27
Swerve
Swerve's Avatar
Naples, Maine
Sandblasting before and after, last week...
Name:	Bronco on way to sandblasting 021.jpg
ID:	406195   Click image for larger version
Name:	Bronco Sandblasted 018.jpg
ID:	406196   Click image for larger version
Name:	Bronco Sandblasted 019.jpg
Old 10/29/16, 10:37 AM   #28
Viperwolf1
electron whisperer
Viperwolf1's Avatar
It's not dented, it's just been environmentally streamlined!
homelessly wandering
That's just crazy. I might build a Bronco from a pile of parts, jump in and drive it from CO to TN and back, head to Moab to wheel it for a few days, drive it straight off the trail for a few thousand more miles before returning home, but that's where I draw the line.
'74 beater, 5.0 mustang EFI, C4, PS, front discs, twin sticks, 3.5" susp/1" body, 33's, 4.11's, ARBs, Hickey Sidewinder, cobra hydroboost
'70 cruiser, 5.8 explorer EFI, 4R70W, PS, front discs + hydro, twin sticks, 3.5" susp/1" body, 34's, 4.88's, ARB & tru-track
Viperwolf1 is offline   Reply With Quote
Old 10/29/16, 10:41 AM   #29
House
House's Avatar
Minutia Militia
Originally Posted by Swerve View Post
We are currently rebuilding the same truck to drive back and race the Baja 1000 again in 2017
Awesome!
SCORE or NORRA?
______
|_____|
(o===o)
||---o-||
House is offline   Reply With Quote
Old 10/29/16, 10:45 AM   #30
Swerve
Swerve's Avatar
Naples, Maine
Originally Posted by House View Post
Awesome!
SCORE or NORRA?
Thanks!
SCORE...
Maybe NORRA later on...
Page generated in 0.37331 seconds with 54 queries
