Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 07/24/16, 09:27 AM   #1
migs
migs's Avatar
NH
Heavy Duty Boomerang styled rear spring shackles.
New boomerang styled rear spring shackles for early Bronco with 2-1/4" wide leaf springs.
They are designed to allow full travel such as the factory style shackle but with the benefit of additional strength.
The sides and cross brace are made from 1/4" thick hot rolled P&O steel and the bushing tube is made from 1-1/2" DOM tubing which has been machined for a good fit.
They are fully tig welded and are available only in bare steel, You will need to coat or paint them as you see fit. They are designed to work with the aftermarket poly bushing offerings (bushings not included).
Sold in pairs as a set. A set consists of a left and a right shackle.
There is a notch on one side of each shackle that faces the inside of the frame hanger bracket allowing clearance for full droop.
The current price per set is $145.00, shipping included anywhere in the continental US.
Please send me a private message if interested or with any questions. Thank You.
I usually have a set or two on hand ready to go. otherwise, I do typically try to have the components ready to go together so I can get them out quickly as needed.
To read up on the making of these CLICK HERE.
Click image for larger version
ID:	405025   Click image for larger version
ID:	405026   Click image for larger version
ID:	405027   Click image for larger version
ID:	405029   Click image for larger version
ID:	405030   Click image for larger version
ID:	405031   Click image for larger version
ID:	405033   Click image for larger version
ID:	405034   Click image for larger version
migs is offline   Reply With Quote
Old 07/25/16, 02:23 AM   #2
Crawdad
Crawdad's Avatar
Spending hundreds on tools to save $10 in repair costs
Columbia, SC
Dadgummit Brian! I haven't even installed your first edition SE #001 yet and you got me wanting some of these puppies! I guess your old ones will stay in a box for forty years and become NOS one day! Your new ones look great, good luck!
Matt
Osan AB
1977 Project uncut tub & frame, 33x10.50x15 KM2s on stock 15x6s, ACC vinyl floor, 6pt Crab Cage, eyebrow grill, 5.0 efi 302, C4 http://classicbroncos.com/forums/sho...d.php?t=229232
76 Ranger SOLD
CarolinaBroncosMember
Crawdad is offline   Reply With Quote
Old 07/25/16, 04:50 AM   #3
malonejy
malonejy's Avatar
U.S. Marine Corps
New Bern, NC
PM sent. I've been waiting for this thread to pop up.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Too many mods to list. She'll go where I point her, but she'll never be done!
malonejy is offline   Reply With Quote
Old 07/25/16, 06:43 AM   #4
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
looks awesome Migs!! another creation from the lab coming to life!
tasker is online now   Reply With Quote
Old 07/25/16, 03:13 PM   #5
Vin218
Vin218's Avatar
Manchester, NH
Put a set on mine a few weeks ago, they look great and are very well made!
1970 uncut. C4 with 4.10s, 3.5" lift with 265x75x16 BFG's
Build thread
Vin218 is offline   Reply With Quote
Old 07/27/16, 07:45 AM   #6
KyleQ
KyleQ's Avatar
1 Ton 74'
Twin Cities
What benefits do these have over the Extreme shackles sold elsewhere?
74' Bronco -Fi-Tech Injected 357W - Twisted Demon C4- AtlasII 3.8 - D60/D70 - PSC Full Hydro - 5.5" lift - Cage Arms, Coils and Shocks - F-O-A 2.5" Air Bumps - 43" TSL SX on H1 Double Beadlocks
74' Bronco Ranger - Street Build in Progress (351W/ZF5/NP205)
KyleQ is online now   Reply With Quote
Old 07/27/16, 09:47 AM   #7
migs
migs's Avatar
NH
My primary concern was achieving full suspension droop such as the factory shackle allows. Prior to these I was making a similar straight shackle, what I discovered is that type of shackle would hit the inside of the spring hanger limiting it's forward movement as the axle/spring would cycle downward.
Here is my thread from when I first started making these showing a comparison to my old style and a factory shackle.
Old 07/27/16, 11:46 AM   #8
KyleQ
KyleQ's Avatar
1 Ton 74'
Twin Cities
I'll take a look at it - the shackles I'm running run into the hanger and are starting to dent it from repeated abuse.
Add it to the list of stuff I need to buy-
Old 07/27/16, 12:08 PM   #9
malonejy
malonejy's Avatar
U.S. Marine Corps
New Bern, NC
That's the same problem I had but luckily I noticed soon enough that I was able to return them.
Old 07/30/16, 06:49 AM   #10
Miker
If you want to give God a laugh, tell him your plans....
Tampa
Man, you are a damn artist. Those things look like you could have worked on each set for hours upon hours. Nicely done and will add them to my list. PM me before a possible price increase
Miker is offline   Reply With Quote
Old 07/30/16, 09:45 AM   #11
navalbronco66
navalbronco66's Avatar
I have a set of the wild horses hd shackles and someone already posted these HD shackles cracking at the welds. They mentioned how the WH stuff didn't allow full movement, like the original shackles. I'm still in the full restoration of my bronco and unfortunately already had the WH shackles, but my order has been placed for these quality items. Don't want future problems.
navalbronco66 is offline   Reply With Quote
Old 08/09/16, 10:37 AM   #12
migs
migs's Avatar
NH
Thanks for the orders!
I have just one set left in stock from this run.
Old 08/11/16, 08:23 PM   #13
Rkeller411
Newbie
Newport Beach, CA
Pm me. I'll take em
Rkeller411 is offline   Reply With Quote
Old 08/13/16, 06:55 AM   #14
migs
migs's Avatar
NH
Thank you for the orders, just sold out of this batch.
Old 08/13/16, 11:40 PM   #15
KyleQ
KyleQ's Avatar
1 Ton 74'
Twin Cities
When will more be available?
Page generated in 0.33279 seconds with 57 queries
