Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 06/26/16, 02:51 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Arrow Serious Armor from Ruffstuff!
This is another one of our "million different uses" type products! Our Universal Tube reinforcements are meant to add wall thickness to your tubing ONLY where you need it! Great for tie rods, lower links, rock sliders, roll cages, and everywhere in between!
•Saves tons of weight and money versus building full sections out of heavy wall tubing.
•The bending and welding makes this reinforcement harder than the tubing it is covering! No more denting tubes.
•Replaceable! If you wear through the reinforcement simply cut along your weld to remove it and weld a new one on.
•Easier and stronger than cutting out and splicing in new sections of cage or rock sliders if a tube is punctured or scraped through!
•Fits on 1.5", 1.75", and 2"+ diameter tubing
•46" length is long enough to cover most full-width axle tie rods from tube insert to tube insert, 1-3/8" wide, 3/16" thick (makes your .25" wall tubing 7/16" wall!)
Universal Tube Reinforcement (Single) - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 07/28/16, 04:07 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
The right way to reinforce a tube, any tube!
Old 09/09/16, 07:08 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
Give it the extra beef BEFORE you break it!
Old 09/27/16, 01:32 PM   #4
Gravel Maker
Quick with a Laser!
Sacramento
A little extra beef where you need it!
Old 10/07/16, 10:58 AM   #5
Gravel Maker
Quick with a Laser!
Sacramento
These are like your kids shin guards, only its for your truck...
Old 10/20/16, 10:29 AM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Dont play too hard until you have the right protection....
Old 11/11/16, 12:14 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
But once you have the right protection, play as hard as you can!
Old 12/08/16, 04:14 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
It's just like putting pads on before going out to play football...
Old 12/19/16, 02:02 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
An essential if you are a beater of suspension components....
Old 01/23/17, 02:04 PM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Wherever you need a little more beef!
Old 03/31/17, 12:43 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Extra meat where you need it!
Old 05/27/17, 01:34 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Level up your character's armor.
Old 06/12/17, 10:26 AM   #13
Gravel Maker
Quick with a Laser!
Sacramento
When it just needs to be a little thicker...
Old 07/05/17, 01:20 PM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Prevent things from bending.... PREVENTatitive maintenance!
Old 08/15/17, 04:18 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Thicker skin is what some things need...
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.33752 seconds with 60 queries
