Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 09/07/17, 08:57 AM   #46
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Ready for your 3rd, axle shafts, and whole vehicle...
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 09/20/17, 03:32 PM   #47
Gravel Maker
Quick with a Laser!
Sacramento
Pure Badassery
Old 10/02/17, 12:27 PM   #48
Gravel Maker
Quick with a Laser!
Sacramento
The last axle you'll ever need!
Old 10/16/17, 01:02 PM   #49
bknbronco
bknbronco's Avatar
BRONCO ENVY.....Its a Jeep thing!
North Metro, MN
will the 11" drum brakes off my stock big bearing big brake axle bolt on? My end flanges are 1/2" bolts, 3.5" apart side to side, and 2 3/8" top to bottom.
Or does everybody just weld on the disk brake kit??
If women cant find you handsom they should at least find you handy!
Gota love the snowball effect...Thats broncoing for ya!
68 frame off project with glass tub and fenders
bknbronco is offline   Reply With Quote
Old 10/17/17, 01:43 PM   #50
Gravel Maker
Quick with a Laser!
Sacramento
bknbronco-
As long as you are running the 'big-bearing' axles then all should work just fine. Ours are for sure 1/2" holes, I'm not a spot currently where I can go measure the pattern, but it is the same as the stock big bearing pattern. From there out, should work with the stock drums, or the common disc upgrades.
Old 01/02/18, 04:02 PM   #51
Gravel Maker
Quick with a Laser!
Sacramento
Badass, and ready to party!
Old 02/16/18, 01:13 PM   #52
Gravel Maker
Quick with a Laser!
Sacramento
Plug, Play, Party!
Old 07/16/18, 02:31 PM   #53
Gravel Maker
Quick with a Laser!
Sacramento
The best out there!
Page generated in 0.30042 seconds with 60 queries
