Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 12/07/16, 07:34 PM   #31
clarrance
clarrance's Avatar
Maryville TN
How much is a stock factory replacement style axle housing?
1969 Sport Red uncut original 64k
1974 Sport Black frame off restoration
clarrance is offline   Reply With Quote
Old 12/07/16, 08:17 PM   #32
nvrstuk
nvrstuk's Avatar
20 gears forward...no reverse!
WA
Free plug....
Check it out here
http://www.ruffstuffspecialties.com/.../FORD9HOS.html
Strrroker powered... 418 cubes, 518 HP, SEFI, EDIS, Still 20+ forward gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607 NWCB Stroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build: http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline   Reply With Quote
Old 12/12/16, 12:13 PM   #33
Crawdad
Crawdad's Avatar
Spending hundreds on tools to save $10 in repair costs
Columbia, SC
Dan,
As Clarance has already asked, do you have any HD style stock axles like the ones found under a 77 bronco? I believe it's referred to as the fish-mouth? I have a 77 rear axle but it has the smaller factory perches. I'm thinking of getting a newer axle with bigger perches and all already welded up and ready for paint.
1977 Project uncut tub & frame, 33x10.50x15 KM2s on stock 15x6s, ACC vinyl floor, 6pt Crab Cage, eyebrow grill, 5.0 efi 302, C4 http://classicbroncos.com/forums/sho...d.php?t=229232
76 Ranger SOLD
CarolinaBroncosMember
Crawdad is offline   Reply With Quote
Old 12/13/16, 03:49 PM   #34
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Crawdad-
The only 9" housing we offer complete as a bolt-in stock replacement is for the 66-77 bronco axles. If your axle is out of a 77 then this one should be a fit, but if it is like a half year change, or an oddball, then you might just want to order up our semi-float housing here (http://www.ruffstuffspecialties.com/catalog/R1981.html) and then get the perches separate and weld them yourself to make sure they fit your spring width.
Hope that helps!
Dan Fredrickson 916.600.1945
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 02/17/17, 05:05 PM   #35
Gravel Maker
Quick with a Laser!
Sacramento
Badass housings...
Old 02/21/17, 01:38 PM   #36
Gravel Maker
Quick with a Laser!
Sacramento
Ready for your shafts, 3rd member, and whole truck!
Old 04/07/17, 10:27 AM   #37
Gravel Maker
Quick with a Laser!
Sacramento
If you are tired of seeing axles smile at you... We've got the cure for that.
Old 04/07/17, 09:04 PM   #38
nvrstuk
nvrstuk's Avatar
WA
Customer service and standing behind their company name and reputation like nothing I've ever experienced... Long story short, Dan and his company have stepped up big time in my case--standing behind their product!
RuffStuff...
Thanks again Dan.
Old 04/19/17, 10:21 AM   #39
Gravel Maker
Quick with a Laser!
Sacramento
We are here for our awesome customers!
Old 05/03/17, 02:36 PM   #40
Gravel Maker
Quick with a Laser!
Sacramento
Give your bronco a sexy rear-end...
Old 06/01/17, 11:46 AM   #41
Gravel Maker
Quick with a Laser!
Sacramento
You'll never need another housing!
Old 06/05/17, 10:56 AM   #42
Gravel Maker
Quick with a Laser!
Sacramento
It's what the men are running.
Old 08/01/17, 02:48 PM   #43
Gravel Maker
Quick with a Laser!
Sacramento
3/8" thick tubes, and 1/4" plate center is a badass combo!
Old 08/01/17, 06:05 PM   #44
nvrstuk
nvrstuk's Avatar
WA
I'll say it is!! Great product!! I'm running the inner seal option on mine...
You're right, you aren't seeing things. That baby is standing on a scale!!
I'm weighing everything I'm taking off and replacing it with on this build...
Click image for larger version
ID:	426331   Click image for larger version
ID:	426332   Click image for larger version
Old 08/28/17, 12:03 PM   #45
Gravel Maker
Quick with a Laser!
Sacramento
Only as heavy as it needs to be, but heavy duty all the way around!
Thanks for sharing!
Page generated in 0.31383 seconds with 54 queries
