Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 09/13/16, 05:04 PM   #16
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
The best housings you can get, and the price is hard to beat!
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 09/14/16, 10:19 PM   #17
nvrstuk
nvrstuk's Avatar
20 gears forward...no reverse!
WA
Work of art for sure...wish I had one!
Strrroker powered... 418 cubes, 518 HP, SEFI, EDIS, Still 20+ forward gears...CB build:http://classicbroncos.com/forums/sho...d.php?t=278607 NWCB Stroker/SEFI/EDIS/4r70W/KluneV/TrueHi9 build: http://northwestclassicbroncos.com/s...n-to-SEFI-EDIS
nvrstuk is offline   Reply With Quote
Old 10/03/16, 09:52 AM   #18
Gravel Maker
Quick with a Laser!
Sacramento
Well let us know when you are ready, and we'll get you one!
Old 10/31/16, 12:34 PM   #19
Gravel Maker
Quick with a Laser!
Sacramento
The housing that wont ever let you down...
Old 11/02/16, 05:30 PM   #20
nvrstuk
nvrstuk's Avatar
WA
Still need to truss this even if you don't jump it? I'm on my 3rd F150 style HD housing so just wondering- thanks.
Also, what options do you have for FF,35 spline with slugs for towing instead of trailering...never hurts to ask!? Thanks
Old 11/04/16, 12:40 PM   #21
Gravel Maker
Quick with a Laser!
Sacramento
Nvrstuck-
If you aren't jumping it, then you will be fine without a truss. These can handle a serious beating just as is, certainly more than even an HD F150 axle, which is still really only a 1/2 ton housing.
I'm not sure what you are asking for about the slugs? Are you talking about manual locking hubs vs drive flanges on a FF axle?
Old 11/04/16, 09:32 PM   #22
nvrstuk
nvrstuk's Avatar
WA
Drive flanges and then blank slugs/covers so I can move it around in 4wd when unhooking for camping or to unhook it after flat towing...
I've bent three F150 housings without ever jumping... hence the need for your housing.
I called and got some good info from your shop- thanks!
Old 11/07/16, 10:29 AM   #23
Gravel Maker
Quick with a Laser!
Sacramento
Great, glad you called!
Sounds like a E-locker, or ARB Diff locker might be what you need. Those you can click a button to lock both wheels, and do easy drifts and doughnuts or general off-roading.
Then with the same click of a button you can unlock to be open and drive easy in parking lots and on the freeway, also doesn't wear tires out so fast.
Old 11/07/16, 12:35 PM   #24
nvrstuk
nvrstuk's Avatar
WA
Yup, been running front D44 ARB since Feb '87 and have progressed from 1st Gen rear ARB in 'early '97 consistently till now with 35 spline - just tore one in half in August. They treated me well as ARB always does!
Still debating about flat towing is all. I think D60 hubs with drive flanges will be strong enough so long as the wheel hub is forged- do you agree?
Once again- thanks!
Old 11/08/16, 02:16 PM   #25
Gravel Maker
Quick with a Laser!
Sacramento
Definitely, you should be just fine.
Old 11/08/16, 08:23 PM   #26
nvrstuk
nvrstuk's Avatar
WA
Are your forged Hubs the same dimensions as stock (flange to WMS)?
so when I get two of yours I can grab a stock one, redrill it for a spare?
Old 11/09/16, 12:04 PM   #27
Gravel Maker
Quick with a Laser!
Sacramento
The exact measurement from Flange to WMS varies a little between the different lug patters of full float hubs, but they are all pretty close, w/in about an inch.
For a spare you would want to order a 3rd of the same forged hub. The spacing that you are talking about is custom on those due to the brake rotor that is primarily used for 5 lug axles.
Old 11/09/16, 08:57 PM   #28
nvrstuk
nvrstuk's Avatar
WA
Ok, sounds good. I need to start tearing things apart and ordering!
Thanks again.
Old 11/25/16, 11:34 AM   #29
Gravel Maker
Quick with a Laser!
Sacramento
The best housings you can get!
Old 12/07/16, 11:22 AM   #30
Gravel Maker
Quick with a Laser!
Sacramento
Get one of these beauties coming your way!
Page generated in 0.32055 seconds with 58 queries
