Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 10/12/15, 08:08 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Cool Bronco Plug & Play Axle Housing!
Ruffstuff Specialties 1966-1977 Early Ford Bronco 9" axle housing is designed to replace the common stock Ford large roller bearing (big bearing) axle housing that your Early Ford Bronco came with. We have done our best to make this a complete plug and play set up for the Early Ford Bronco enthusiast. You will just simply swap housings and your internal components! The housing will come complete with 1/2" hole big bearing flange cups. Heavy Duty 7-3/4" long anti-wrap spring perches will be fully welded, over sized screw in fill.
Our Early Ford Bronco housing features 3.5"x3/8" wall DOM axle tube for starters! Then we combing the heavy duty center section with an A36 plate steel at 1/4" thick, while using a 3/8" face plate that has been fully machined after welding for excellent stud retention. The seal surface is also for stock or after market third members. The center section is also internally gusseted and reinforced 7 ways to add even more strength. This will keep the axle housing from flexing under load which commonly happens in a stock Ford 9" axle housing when just adding tires.Keep in mind you might want to purchase our thick 5/8 u-bolts an u-bolt plates to accommodate the 3 1/2 axle tube!
*NOTE* Heavy duty anti-wrap spring perches will be standard installed and welded to the housing in the factory location. Please specify if you need the perches to be adjusted in their placement to compensate for a different pinion angle than the factory set up.
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 11/14/15, 04:55 PM   #2
Elite Broncos
Elite Broncos's Avatar
I have one and it works great. Highly recommended. Fit like a glove
Elite Broncos is offline   Reply With Quote
Old 11/20/15, 12:23 AM   #3
Gravel Maker
Quick with a Laser!
Sacramento
Thanks for the recommendation!
Old 11/21/15, 10:18 AM   #4
JB Fab
JB Fab's Avatar
The doctor said "if it hurts, don't do it"
Salem, Oregon
Top shelf stuff! Excellent fabrication and design. Looking forward to installing ours.....
JB CUSTOM FABRICATION LLC
www.jbfab.net
JB Fab is offline   Reply With Quote
Old 11/24/15, 07:40 AM   #5
vintagebronco75
vintagebronco75's Avatar
Hillsboro, Oregon
Great looking housing with lots of reinforcement, hate to cover up the pretty welds.
Still need to find some u-bolts, seals and studs before I can install it, wish it would have come with the housing or given an option to order some from you guys.
vintagebronco75 is offline   Reply With Quote
Old 01/02/16, 09:58 AM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Sorry for the late response but we make all of those pieces...
Old 01/16/16, 07:54 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Time to rethink your plans
Old 03/14/16, 12:03 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Bigger and stronger Axle shafts and lockers are essential, but the housing needs to be loved as well!
Old 03/15/16, 12:33 AM   #9
Elite Broncos
I have one and love it! It fits like a glove.
Old 03/28/16, 10:57 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
He even got to show it off with us at Off-Road Expo last year...
Old 04/12/16, 07:05 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Plug and Play ladies, what are you waiting for! ;-)
Old 04/26/16, 06:52 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
These are works of art if you ask me!
Old 05/16/16, 08:57 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
A 9" housing you won't be able to bend!
Old 06/15/16, 01:41 PM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Ready to drop in your 3rd, and axle shafts!
Old 07/12/16, 03:03 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
The last housing your 9" will ever need!
Page generated in 0.30754 seconds with 61 queries
