Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat
Old 11/11/17, 02:58 PM   #796
txtruk15
txtruk15's Avatar
Long time Bronco lover, new owner
Highland Village, TX
Originally Posted by duffymahoney View Post
Thanks!
I don't like painting screws
Lol, yeah the paint does tend to flake off the first time you screw them in. I'd say powdercoat but too much trouble and white is hard to match...
Sent from my SM-G955U using Tapatalk
' _____
|_____|
'70 Sport, '87 5.0L, 37x17s, Dana 44 & 9",
(o===o) lockers, Dana20, 4.56 gears, Icons,
||---o-|| Logans bumpers, mastercraft, superwinch
txtruk15 is offline   Reply With Quote
Old 11/11/17, 04:44 PM   #797
5001craig
5001craig's Avatar
Stock is what you make soup with.
NE Indiana
eBay: 5001craig
Awesome build/thread. I always check it. Thanks for the help.
What is the color you went with (looked back and couldn't find it)? I really like that color. Not that I will ever get to the body but it's nice to dream.
'74 Explorer 408W/C4/Atlas 3.0/35 spline rear/discs & Grizzly's front & rear/Duff Monster 3.5" with 4-Link Rear/2" BL/Painless...
My build thread.
5001craig is offline   Reply With Quote
Old 11/11/17, 05:33 PM   #798
txtruk15
txtruk15's Avatar
I think it's in post #682....
' _____
|_____|
Old 11/21/17, 03:22 PM   #799
duffymahoney
1977 Re-Uncut, 5.0, Someday daily driver
Sandpoint Idaho
Working on the amp power steps, delonicks brackets don't work that well, or my bronco is too far off from what they were designed after. Angles are wrong on the brackets, holes aren't perfect, nothing lines up etc... I wish I would have just designed my own. Hopefully others are having better luck than I am.
The amp arms call for a 10mm bolt (through the bottom of the rocker- pinch weld into the amp arms), which is pretty huge, and barely fits (height wise) on the pinch weld/ rocker, then you have a washer, which does fit, but that is assuming the bracket lines up perfect. I ended up reaming out my holes even larger and still having issues, I ended up deciding on just putting a 5/16 bolt through and using a nut instead of the 10mm that threads into the bottom of the arms. 5/16 with washers will hide the mistakes, but still not happy with it.
Side note Nick Menudier told me about Rotobroach metal hole cutting bits. Left is a traditonal bit that was super sharp, right is the same size bit but a rotobroach. Wow what a difference.
Click image for larger version
ID:	435321   Click image for larger version
Build Thread: Updated list of what I have done is on page one-
http://classicbroncos.com/forums/sho...d.php?t=259028
duffymahoney is offline   Reply With Quote
Old 11/21/17, 04:54 PM   #800
bronco loco
It never ends
bronco loco's Avatar
I'm Broke because I own a BronKo
Valley Stream L.I.
I'm hoping I don't have the same problem, have exactly the same set up and will be dealing with it next week once I bring the truck back home.
72 Sport uncut, 2.5 WH front coils 3.5 WH rear leaves pack
98 Explorer drivetrain
bronco loco is offline   Reply With Quote
Old 11/21/17, 04:55 PM   #801
duffymahoney
Sandpoint Idaho
I would give up on the 10mm.
Old 11/21/17, 05:34 PM   #802
bronco loco
It never ends
Valley Stream L.I.
I will let you know how it works out. Thanks for the heads up.
Old 11/21/17, 07:50 PM   #803
tirewater
Orinda, CA
If you can get to the back side, a knock out punch does a nice job of making a round hole. HF has a cheap set, but if you invest make sure they're sharp enough so they don't warp the sheet metal.
https://www.harborfreight.com/knocko...-pc-60575.html
The Rotobroach hole looks nice. Do they come with pilot bits so they doesn't walk when starting the cut?
1976 Ranger, AT/PS/PB
tirewater is offline   Reply With Quote
Old 11/22/17, 10:04 AM   #804
duffymahoney
Sandpoint Idaho
No pilot bit, you drill a 1/8 hole then the bits have a pointed end. Super clean. I will never use anything else.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 11/22/17, 11:01 AM   #805
englewoodcowboy
Lick Creek Restorations
englewoodcowboy's Avatar
"The Duck"
Ceres, VA
Thanks for the tip on the bits. I use a rotobroach when cutting the vent holes in the dashes but never thought to see if they made smaller ones. Thank you for spending my money Duffy. LOL
BoxWood Green Poly '73 (o===o) 347 Stroker, FiTech Go EFI, Explorer Serp, 2.5" WH SL w/Bilsteins, AOD, Hydroboost PB, TrueTrac LS Rear, 4.88 gears, 35" BFG ATKO2, F150 Front Disc Brake, Factory PS, Family Cage ctsy Nick's Trix, AC, Stereo System, PWR Windows, Locks & Steps My Build.
englewoodcowboy is offline   Reply With Quote
Old 11/26/17, 07:42 PM   #806
duffymahoney
Sandpoint Idaho
Finally got my custom stainless 77 gas tank installed. Fits with about a 1/4 to spare. Should be about 23 gallons. 14 gauge and I used an fittings where I could. Doesn't hang down any further then my stock tank. It has a linear fuel level gauge.
ID:	435751   Click image for larger version
ID:	435752   Click image for larger version
ID:	435753   Click image for larger version
ID:	435755   Click image for larger version
Old 11/27/17, 01:27 PM   #807
sprdv1
REBEL
sprdv1's Avatar
Guess you better call the Whaaaambulance
Lees Summit-Missouri
Looks Tough.. (good way)
sprdv1 is offline   Reply With Quote
Old 11/29/17, 11:44 PM   #808
duffymahoney
Sandpoint Idaho
Worked on something fun tonight. My spare tire license plate holder/led was a bad design. Rattles would have been terrible. So I welded a stainless nut on and make a T handle stainless bolt. Should work great. The little things are my favorite to figure out.
ID:	435966   Click image for larger version
ID:	435967   Click image for larger version
ID:	435968   Click image for larger version
Old 11/30/17, 11:05 AM   #809
englewoodcowboy
"The Duck"
Ceres, VA
I am about to try my first set of the power step brackets from Nick. I like your idea on through bolting the lower bolt. To fit the pinch weld they are tight no matter what so I am thinking of drilling out the threads in the bracket and making it through bolt like your suggestion. I will let you know how everything lines up as soon as I get around to installing it.
Old 11/30/17, 11:09 AM   #810
duffymahoney
Sandpoint Idaho
Awesome, I know have giant holes in my drivers side pinch welds I can cover 95% of all of them, but still beyond lame. What size bolt will you use? I didn't think of drilling out the threads. I got some ARP stainless bolts for mine.
Page generated in 0.43624 seconds with 54 queries
