Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 10/17/16, 01:01 PM   #76
gearida
gearida's Avatar
Badest Bronco in the World, that lives on my Block!
Newburgh, IN
I don't like pickle forks, put the castle nut on upside down and hit the hole side of the arm with a hammer. The tie rod should pop right out and not damage anything.
'76 5.5" JD Monster suspension with a 2" body lift. 35" KM2s with Walker Evans 17X8.5s. 351 cu"/ NP435. Still in project mode.
gearida is offline   Reply With Quote
Old 10/17/16, 06:47 PM   #77
broncojack
broncojack's Avatar
Broncos Rule!
Chicago
The reason I asked on how to remove it was, I didn't think hitting the tie rod end with a 5 pound hammer was wise. As you know the drag link is attached to the tie rod.
If it was the steering knuckle I can see hitting it with a hammer.
The dust boot on my rod end will not work with "the cure"
1976 Sport Bronco
1974 Ranger
1971 Baja Bronco
2 1967 Sport Bronco's U15 & U14
broncojack is offline   Reply With Quote
Old 11/01/16, 10:16 AM   #78
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Tighten up that steering!
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 11/10/16, 03:54 PM   #79
Gravel Maker
Quick with a Laser!
Sacramento
Make your truck track straighter then you might be ;-)
Old 12/12/16, 11:18 AM   #80
Gravel Maker
Quick with a Laser!
Sacramento
No more bouncing from white line to yellow line... this is like sobering up your steering!
Old 02/17/17, 05:07 PM   #81
Gravel Maker
Quick with a Laser!
Sacramento
Bouncing between the lane lines isn't fun.
Old 05/15/17, 10:18 AM   #82
Gravel Maker
Quick with a Laser!
Sacramento
Get a little more 'feel' at the wheel.
Old 07/28/17, 09:56 AM   #83
Gravel Maker
Quick with a Laser!
Sacramento
Cure the wander-lust of your steering ;-)
Old 09/15/17, 10:23 AM   #84
Gravel Maker
Quick with a Laser!
Sacramento
Tidy steering is a nice feeling.
Old 09/15/17, 10:45 AM   #85
reynard101
reynard101's Avatar
Tempe, AZ
Site says, "Out of Stock"
reynard101 is offline   Reply With Quote
Old 01/11/18, 10:49 AM   #86
Gravel Maker
Quick with a Laser!
Sacramento
In stock and ready to party!
Page generated in 0.30919 seconds with 58 queries
