Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 06/30/16, 02:03 PM   #61
DirtDonk's Avatar
San Jose, CA
I also think GravelMaker said it's recommended for one end only, and also not for use on the tie-rod ends at the knuckles for some reason.
It's also probably not necessary to use up at the top. It's the tie-rod that does most of the rolling anyway, and not the draglink. And lots of angle change up there that is desirable to not try to resist. Lots of stress added I would think.
You have an issue you're dealing with Mike? Or just curious more than anything else?
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is online now   Reply With Quote
Old 06/30/16, 08:02 PM   #62
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
The reason it is not used at the knuckles is involved with the Ackerman steering angles all modern vehicles (since 1950 or so) use. When you turn the inside tire leans into the turn. The Cure would inhibit that lean to the point of bending the Tierod.
BTW, it can work well with the inverted T style of steering and with all the years on an EB accidents can accumulate and sometimes wander is introduced into the system by a fender bender you don't even know of from 25 years ago.
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 07/01/16, 07:34 PM   #63
Mike42p
Mike42p's Avatar
Virginia Beach
eBay: Mike42p
No not necessarily. It just seemed I had a bit of play up there. I definitely have some roll at the point the drag link meet tie rod though. I'm gonna give this a shot. Thanks though!!
Uncut '76, 302, 5.5" lift, 285/70R17, work in progress
Mike42p is offline   Reply With Quote
Old 08/14/16, 03:40 PM   #64
broncojack
broncojack's Avatar
Broncos Rule!
Chicago
I just installed the Cure, it doesn't look right. Should I open up the hole so the tie rod slips in farther?
Click image for larger version
ID:	402013   Click image for larger version
ID:	402014   Click image for larger version
1976 Sport Bronco
1974 Ranger
1971 Baja Bronco
2 1967 Sport Bronco's U15 & U14
broncojack is offline   Reply With Quote
Old 08/14/16, 07:36 PM   #65
DirtDonk's Avatar
San Jose, CA
Can you take a shot from slightly farther away to show the whole draglink?
Looks like yours is rotated slightly out of true, which is twisting itself enough to open up that gap. Plus yours might not be the same brand or rod ends as tested by Ruff Stuff, so might have a slightly different profile anyway.
But it looks like it could work if the twist was gone.
Maybe even a little judicious grinding of the Cure piece to allow for that angle if needed, but try to twist things first.
Since your draglink is likely an adjustable one, you should be able to loosen the sleeve clamps and rotate the lower end to suit.
Or is it straight in relation to the upper end already, and it just twists itself during movement?
Good luck. Definitely don't want that gap if you can avoid it.
Old 08/15/16, 05:04 PM   #66
Gravel Maker
Quick with a Laser!
Sacramento
It needs to be tighter. Is the pin fully seated? That is definitely the way it is meant to be used but it is deeper seated so each surface are touching metal.
Either your TRE has a longer pin or the taper is not deep enough. If the taper is deep enough you can add a steel, brass, or plastic washer between the flat surfaces to fill the gap... Your TRE (not the Y link) appears to be a high angle variety and their pin is longer but the high angle is not needed their so I would think spacer.
Old 08/17/16, 03:47 PM   #67
broncojack
broncojack's Avatar
Broncos Rule!
Chicago
I got a chance to work on it today.
The pin is seated all the way and the cure has some movement and I can even wobble it a little. I will try a washer and tighten it up.
Can you tell me which end on the drag link has the left hand thread and which is right?
Thanks Jack
1976 Sport Bronco
1974 Ranger
1971 Baja Bronco
Old 08/18/16, 09:18 AM   #68
Gravel Maker
Quick with a Laser!
Sacramento
The left side is RH thread and the right side is LH thread, don't ask me why...
Old 09/12/16, 09:02 AM   #69
Gravel Maker
Quick with a Laser!
Sacramento
Tighten up the wander in your steering!
Old 09/29/16, 05:47 PM   #70
Gravel Maker
Quick with a Laser!
Sacramento
Small things that make a big difference!
Old 10/09/16, 01:16 PM   #71
broncojack
broncojack's Avatar
Broncos Rule!
Chicago
What do you recommend you use to remove the tie rod ?
Pickle fork?
1976 Sport Bronco
1974 Ranger
1971 Baja Bronco
Old 10/09/16, 05:09 PM   #72
Gravel Maker
Quick with a Laser!
Sacramento
Pickle forks usually do work well, also just using a hammer to shock-load the knuckle or TRE while applying a little leverage to the TRE usually works pretty well.
Old 10/16/16, 02:08 PM   #73
broncojack
broncojack's Avatar
Broncos Rule!
Chicago
The pickle fork did a number on it.
Do you still think I should use it or is it trashed?
ID:	405508   Click image for larger version
ID:	405509   Click image for larger version
1976 Sport Bronco
1974 Ranger
1971 Baja Bronco
Old 10/16/16, 02:29 PM   #74
DirtDonk's Avatar
San Jose, CA
Well bummer. As you found out, never use a pickle fork on anything you hope to reuse.
Many a rubber dust boot has fallen to the superior strength of a pickle fork!
It's very possible that your Cure might still function in it's anti-roll role. But if it has to do any sealing (grease in and weather out), that part of it's life might be over.
Still worth a try, just in case it's still got some life in it. But it's looking sketchy at the moment.
I think Gravel Maker was thinking you were referring to the tie-rod ends at each end of the rod where they join the knuckle. Not the draglink at the tie rod.
I know that's what I was thinking at least, when I saw your question.
His other suggestion of the hammer-to-the-side method (not hitting the shaft, stud, nut, or rod end itself) to distort the tapered interface would not mess up the disc. So would have been a better method for the drag link end. At least as a first attempt.
If that didn't work then the pickle fork might have been your only recourse.
Old 10/17/16, 09:46 AM   #75
Gravel Maker
Quick with a Laser!
Sacramento
Thanks Paul!
And that is all correct BroncoJack, the roll-control nature of your cure could still work, but if it cannot fit with the TRE dust boot (some do, some don't) then you are going to have a sealing problem keeping grease in, and dust/dirt/water out.
Sorry that happened, and I should have more strongly recommended the hammer method perhaps. Keep us posted on what you end up doing, and how well it ends up working!
Page generated in 0.42117 seconds with 60 queries
