Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 01/27/16, 02:18 PM   #46
mrdrnac
mrdrnac's Avatar
Mesa/Show Low, AZ
Was it the R2008 jeep part number you ordered? Please do let us know if it works OK!
mrdrnac is offline   Reply With Quote
Old 01/27/16, 02:40 PM   #47
boogie
boogie's Avatar
Lafayette La
Yep ok will do
Excuse all the dumb nuwbie ?'s
68 Sport 3.5 lift 31's
boogie is offline   Reply With Quote
Old 03/11/16, 07:45 PM   #48
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
This easily gets rid of the 'Dead Spot' in your steering, try it out if you have a Y-Link!
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 03/12/16, 07:38 AM   #49
BroncoJimbo
76 Bronco together over 26 yrs
Atlanta, GA
I am fighting a wandering problem. Does this wok with the stock 76-77 linkage?
BroncoJimbo is offline   Reply With Quote
Old 03/12/16, 12:50 PM   #50
DirtDonk's Avatar
San Jose, CA
Not speaking for Gravel Maker here, but I'd have to say no it won't work for you.
It might "fit" but it would have different levels of effectiveness because your linkage is entirely different. They might both be called "Y" by some, but yours is the original "Inverted-Y" style that most of us refer to. In spite of the fact that RuffStuff is correct to say theirs looks like a "Y" (it does!) it's in effect what we would refer to as a modified version of the old "Inverted-T" linkage setup.
Your wandering is likely due to several different things working together, but not an inherent design flaw.
Did you start a thread asking about your issue? If not, let's do that so you can get a bunch of suggestions of different things to look for.
And a detailed description of what changes to your Bronco have been made (especially suspension height) and some pics of your steering layout and wheels and tires.
Good luck.
'71 Wagon, 3.5" WH, F150 disc brakes and steering, 4.11 33x11.50 Thornbirds, Kayline soft top, Hanson bumpers. "Built, not bought"
'68 LUBR, 2.5 + 1 WH, 31x10.50, 4.56, Explorer and 4R70w by EFI Guy, WH disc brakes, Hanson front bumper, Warn winch. "Bought, not built"
www.wildhorses4x4.com
DirtDonk is offline   Reply With Quote
Old 03/13/16, 09:36 AM   #51
BroncoJimbo
Atlanta, GA
Thanks Paul.
Been chasing this wandering problem for a while. I am going to try one more thing and if that doesn't work I'll pose the question to the board.
Old 03/23/16, 07:20 PM   #52
Gravel Maker
Quick with a Laser!
Sacramento
Jimbo-
Thanks for your question, and there is a chance it could work just fine, but not a guarantee I'm afraid. The primary difference is the amount of space between the body of the ball joint and the face of the link with the tapered hole. (doesn't matter if it is our style y link or the inverted T or Y link).
The two that we have, one was designed to work with all of our GM 1 ton TREs (the white colored one). Some customers have found that they fit other TRE brands, while others are shaped differently enough to where it just doesn't make contact.
The other one (black color) is designed to fit the stock Jeep Cherokee and most Wranglers for those still using stock TREs.
Your Ford ends are not something we have tested them on as of yet I am afraid. But it may be that one of them is easily trimmed or modified a little bit to work. If you wanted to try it out, you could order both the black and white one and just test fit to see if one works or could with a little love. If one or both don't work we are happy to return them, and you would only be out a few bucks in shipping.
Or... there is no time like the present to upgrade to GM 1 ton steering... (sorry, gotta be a salesmen every once in a while ;-) )
http://www.ruffstuffspecialties.com/catalog/YLINK.html
Old 04/04/16, 11:19 AM   #53
Gravel Maker
Quick with a Laser!
Sacramento
Monday is here once again, several steering kits and Cures by themselves headed out today.
Old 04/18/16, 11:46 AM   #54
Gravel Maker
Quick with a Laser!
Sacramento
Cure the wander in the wheel!
Old 05/03/16, 10:45 AM   #55
Gravel Maker
Quick with a Laser!
Sacramento
Your truck will drive like it's brand new!
Old 05/05/16, 10:39 AM   #56
hyghlndr
Delaware ????
Why not make a set that will fit the stock setup that most here are running?
hyghlndr is offline   Reply With Quote
Old 05/05/16, 10:55 AM   #57
DirtDonk's Avatar
San Jose, CA
Because the stock setup doesn't need it.
This is a product that's being produced to fix an issue associated with modified steering linkages. Stock does not have the same problem. Unless other changes have been made to cause it that is, or the rod ends are so worn out that they can't hold their position any longer.
Old 06/04/16, 04:49 PM   #58
Gravel Maker
Quick with a Laser!
Sacramento
DirtDonk is correct, stock bronco steering does not need this, however our (or other peoples) Y link 1 ton steering kits are a semi-common swap, and this vastly improves how a Y link handles.
Old 06/30/16, 10:06 AM   #59
Mike42p
Newbie
Mike42p's Avatar
Virginia Beach
eBay: Mike42p
Would this also be applicable to the end of the drag link that meets the pitman arm?
Uncut '76, 302, 5.5" lift, 285/70R17, work in progress
Mike42p is offline   Reply With Quote
Old 06/30/16, 01:50 PM   #60
chuzie
chuzie's Avatar
God, Family, Country, Bronco
Tampa, FL
I think I asked the same thing and believe it was no. Double check though.
Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk!
'77 351w-EFI, 4R70W, 4-link, lockers, 4.56, 35" MT/Rs with a severe rock addiction.
Roads? Where we're going, we don't need roads.
chuzie is offline   Reply With Quote
Page generated in 0.30260 seconds with 54 queries
