Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 02/16/15, 12:29 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
The Cure for your Tie Rod Roll!
Finally!
For as long as there have been off-road vehicles they have wandered down the road. Wandering along...
If you have driven one, you know the feeling. The steering wheel goes two inches to the right, two inches to the left and then back again, while your vehicle stays in a relatively straight line. That is the result of your Tie Rod rolling forward and backward forward and backward again and again. That's simply because there is nothing there to prevent it from doing that. And early wear on tie rods simply because they are always in motion and torn boots because they have been flexed about a jillion times.
The Cure!
This small piece of machined Delrin plastic has had a lot of thought put into it. So much that we decided it would be the First Ruffstuff product we patented! Used against only the face of our Y-Link Adapter or a common Y-Link Tie Rod. It gives a self lubricated,fixed yet slightly flexible surface for the Tie Rods to run against. The drag link does not flop forward or backward whatsoever yet in common usage it is allowed to roll which causes the steering wheel dead spot and allows for the tie rod roll.
Not all TRE's are created equal. Some have a long pin, some have a short pin. This product has been specifically made to work with a GM 1 Ton TRE. In some cases you may have to sand the outside surface to allow for a flush fit. You do not want a tight fit, you want a snug fit. It naturally has a grease pocket built in, this is meant to ride beyond the taper in place of the standard dust boot. These are made for 1 Ton TRE's and also work for 7/8" Heim Joints.
This product also goes great with our Offset Tie Rods if you also use our second pattented item, our Y-Link Adapter that you can find here Y link adapter 18TPI (TRE threading) - RuffStuff Specialties When using these 2 together you still retain the fine adjustability of a standard Tie Rod!
The Cure! - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 02/20/15, 02:08 PM   #2
Broncitis
MEB Founder
Broncitis's Avatar
York
Why would anyone one here drives Jeeps?
Broncitis is offline   Reply With Quote
Old 02/20/15, 05:03 PM   #3
chuzie
chuzie's Avatar
God, Family, Country, Bronco
Tampa, FL
People always tell me they like my Jeep. I snarl and reply with "Thanks" as there is no sense in trying to correct them.
I run GM 1 ton tie rods. How much are these?
'77 351w-EFI, 4R70W, 4-link, lockers, 4.56, 35" MT/Rs with a severe rock addiction.
Roads? Where we're going, we don't need roads.
chuzie is offline   Reply With Quote
Old 02/20/15, 07:01 PM   #4
Doyle
Doyle's Avatar
East Tennessee
$19.00 each http://www.ruffstuffspecialties.com/catalog/R1768.html
73 Ranger, 351W, LTs, duals, Duffs floor shift, twinstick, PS, PB, 78 front disk, T-bird calipers, True Track, RCV, Exploder rear disk, Detroit 35 spline, BCB 3.5" springs, Cage shocks, K30 TRO, Warflares, homebuilt trackbar riser, bumpers & boxtube rockers
Doyle is offline   Reply With Quote
Old 02/21/15, 10:52 AM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Apologies for it saying Jeeps. I was spreading it around the forums we market on & forgot to change it.
And to the common pedestrian, every SUV is a Jeep lol.
"Hey nice Jeep!"
"It's a Ford Explo.........nevermind"
Old 02/23/15, 03:40 PM   #6
krashnpa
krashnpa's Avatar
Burning Metal
Mounted Joy, PA
I think JCR Offroad has been selling something like these, but I don't think they are machined.
krashnpa is offline   Reply With Quote
Old 03/15/15, 07:00 PM   #7
bigmuddy
bigmuddy's Avatar
Consensus is not science!
Marthasville MO
eBay: bjf68
Is this most prevalent on the drag link? meaning I need to buy 2? Or do I need to buy 4 and one each for each TRE?
What do you recommend?
Thanks!
75 EB, 35" tires, EFI 5.0 with Explorer stuff. ARB/ Aussie locker, ZF tranny, 4.56 gears, twin stick, 2.5 BC lift, Cage long arms and dual shock kit,Ghetto fab hydroboost with disc brakes,yada,yada,yada!
bigmuddy is offline   Reply With Quote
Old 03/15/15, 07:50 PM   #8
roundhouse
Lost in space
Gonna make em for the stock tie rod?
"Do we really think that a government-dominated education is going to produce citizens capable of dominating their government, as the education of a truly vigilant self-governing people requires?" [Alan Keyes]
For some, Freedom matters, for most, prosperity suffices. [Fred Reed]
EFI, NV3550
roundhouse is offline   Reply With Quote
Old 03/16/15, 07:26 AM   #9
bigmuddy
bigmuddy's Avatar
Marthasville MO
eBay: bjf68
Looking at the website, it would appear two are needed and just for the draglink TRE.
Old 03/17/15, 07:48 AM   #10
Bart
Broncos Rule!
Victorville
What needs to be mentioned here is that these products are for DOM steering setups, correct me if I'm wrong there R.S. I bought and installed these two pieces in my '66 EB. Looks good and is fine on the street. While I didn't go with this to cure the 2" steering issue (ram assist kinda gets rid of that), but moving from the, twice bent, F150 system to DOM steering tubes and one ton GM Tie Rod ends I had no place to land the drag link. This was about the time they came out with the adapter for the "Y" link and the white bushing. Connecting the drag link to the tie rod is now not a problem. I believe you can buy the white bushing to replace the rubber one without a problem. The rubber one I speak of is at the junction of the drag link to the Tie Rod (aka center link)
I do wonder if these with bushings would work on the tie rod ends? What do you think of that idea R.S.????
This next weekend at the Arizona Stampede will tell the truth of it's worth. So far it looks like it's worth the money.
66 w/ TBI 351W, AOD w/super coupe gears, "TRU HI 9" w/Detroit locker & 35 spline axles; 44 OX diff. 5.5" susp lift/1" body lift. 203/205 t-cases new sheet metal floors. 35" MTRs. Best top. Custom built spare tire rack. 5.13 gears.
Bart is offline   Reply With Quote
Old 03/18/15, 08:59 AM   #11
BoureeOne
BoureeOne's Avatar
Baton Rouge, La
Email to and from the guys at Ruff Stuff. Placed order today...
Scott-
Yes, It looks like you do have a Y-Link steering setup, and again you are correct that it only goes where the drag link connects to the tie rod. These are specifically for improving street handling, it tightens up the steering and eliminates most of the 'dead spot' in the steering wheel input.
It should be a good fit for your vehicle and axle setup. \
Thanks for your interest in our parts!
Kyle
On Tue, Mar 17, 2015 at 7:04 AM, Scott D. Russell <scott.russell@kimbledevelopment.com> wrote:
I am doing a resto/mod on my 66 Bronco. Read about your product, “The Cure”, on the Classic Bronco Website. I have a D30. Based on what I have read, I think I only need one of these to mount where the draglink connects to the tie rod. Based on the picture attached, would that be correct? If yes, do you think this product would benefit me? My rig will be for street use only, no off road at all. I will be running 31x10.5x15 all terrain tires. Thanks for your help.
"Flying Tiger" '66 U15 Wagon, 347 Stroker, FiTech, Tremec TKO 600 5spd, 4:11, A/C, PS, PB
BoureeOne is offline   Reply With Quote
Old 03/24/15, 08:41 PM   #12
bigmuddy
bigmuddy's Avatar
Marthasville MO
eBay: bjf68
Just ordered one. Anxious to see if this fixes my ride!
Old 03/24/15, 09:26 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Sorry for no quick answers guys but I have been in the hospital. Give the shop a call with questions. I will say these are not for at the knuckles but only for the Y link hole. You need the movement at the knuckles for the Ackerman to allow the tire to tilt into the turn so using these there would stop that. At the Y link you can eliminate the roll by tying it to the drag link...
Old 04/01/15, 09:18 PM   #14
Gravel Maker
Quick with a Laser!
Sacramento
They work!
Old 04/02/15, 07:58 PM   #15
chuzie
chuzie's Avatar
Tampa, FL
Is this chevy tro setup an applicable candidate?
Click image for larger version
Copyright © 1996-2018 All rights reserved. Privacy Statement
Page generated in 0.33057 seconds with 61 queries
