Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 01/29/15, 12:51 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Our 14 Bolt Pinion/Truss Bridge!
This is an easy decision. The welds on the 14 Bolt tubes have been known to fail when you have high HP so this bridges the strength gap.
This comes as part of our 14 Bolt Truss Kit but it is very easily adaptable to any truss made by a shop or a home Fabricator. It has enlongated holes so it can be used with any companies Pinion Guard, our Pinion Guard, or with no pinion guard.
The Bridge has 2 weld in Gussets to eliminate any flexibility.
The Pinion Guard Adapter comes with bolts for the Truss end but not for the Pinion end. We do not add them because GM used 2 different threads over the years and not every Pinion Guard has the same thickness as ours. This will work with any Pinion Guard or Truss.
14 Bolt Pinion Truss Bridge - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 05/01/15, 12:05 PM   #2
Gravel Maker
Quick with a Laser!
Sacramento
You've kept us busy all week! Let's keep it going through the weekend!
Old 10/20/15, 09:11 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
Time to get that Ujoint protection!
Old 03/16/16, 11:26 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Strength and protection! Two things our rigs can't get enough of!
Old 03/30/16, 11:47 AM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Armor and strength for the U joints and the axle housing itself, a great pair!
Old 04/14/16, 08:59 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
Easy to fit the bridge to almost any store-bought or home-brewed axle truss.
Old 05/03/16, 10:44 AM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Don't find yourself staring at a twisted tube weld on the trail, wishing you had given it the support it needed...
Old 05/16/16, 08:56 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
Even strong axles like the 14 bolt don't mind some extra support!
Old 06/08/16, 04:25 PM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Add in one of our 3/8" diff covers and your 14 bolt will be as protected as it can possibly be!
Old 08/30/16, 07:01 PM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Going 1 ton? There are some great choices!
Old 09/22/16, 12:20 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Extra strength for an already strong axle...
Old 10/22/16, 07:38 PM   #12
Gravel Maker
Quick with a Laser!
Sacramento
Protection for the U joints is key...
Old 12/04/16, 02:21 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
This is what you need!
Old 02/03/17, 10:09 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
If you've gone by way of the 14 bolt... This is a bell/whistle you're going to want. Plus it looks awesome.
Old 04/21/17, 10:12 AM   #15
Gravel Maker
Quick with a Laser!
Sacramento
Gone the 14 bolt route? make sure the axle never let's you down and support it!
Page generated in 0.31475 seconds with 56 queries
