Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/14/14, 03:47 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Ruffstuff 9" Third Members!
We build these the way I would build them for myself. All have 1350 Pinion Yokes, Solid Spacer, Big Bearings, Daytona Pinion Support, Timken USA Bearings, and a Strange Nodular Iron case that has all the extra strength built into it.
All you need to decide is the type of locker you want (ARB, Detroit, or Spool), your gearing choice, and shaft diameter. The only ARB's we offer are the new designed 9". We do not offer a "True Trac" or "Open" kind of option. These are made only for 31 or 35 spline shafts. We offer the best at a great price.
You can always stop by and pick them up if you are in the area but we only ship them in a bombproof carrier designed specifically for shipping Ford 9" 3rd's. This is at no extra charge to you and a whole lot easier than an insurance claim
Check out the website for prices and you can order them online or call in your order. I will not be giving quotes here, we are simply way too busy for that...
Also, for the first 30 days we are making these an even better deal! 15% off Use the code NEW3RD...
Ford 9" Complete Third Members - RuffStuff Specialties
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 08/26/14, 03:06 PM   #2
lynn w gray
saw your add, I need 9" with Detroit soft, 456, 31 spline. shipped to Louisiana 71360
1974 ford bronco. thanks lynn 318-229-2264. do you offer axles also ?
lynn w gray is offline   Reply With Quote
Old 10/01/14, 09:31 AM   #3
Gravel Maker
Quick with a Laser!
Sacramento
These were built for the beating!
Old 03/25/16, 11:19 AM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Ready to drop in and party on!
Old 04/12/16, 07:02 PM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Any gear ratio you need, and the 3 most common lockers. Let us know how we can help!
Old 04/25/16, 10:57 AM   #6
Gravel Maker
Quick with a Laser!
Sacramento
And you get to keep the badass Shipping container we send them in.
You're welcome!;-)
Old 07/20/16, 01:51 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
Packed and ready to your door!
Old 08/31/16, 08:33 PM   #8
Gravel Maker
Quick with a Laser!
Sacramento
All the best stuff!
Old 09/28/16, 10:14 AM   #9
Gravel Maker
Quick with a Laser!
Sacramento
Quick turnaround too! We have these professionally built and sent out the door in only a couple of days!
Old 10/22/16, 07:37 PM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Ready to build it however you want it!
Old 11/11/16, 12:13 PM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Pairs nicely with one of our housings ;-)
Old 12/12/16, 11:18 AM   #12
Gravel Maker
Quick with a Laser!
Sacramento
The 3rd member that will get you there!
Old 02/17/17, 05:03 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Just what the good doctor ordered!
Old 04/21/17, 10:11 AM   #14
Gravel Maker
Quick with a Laser!
Sacramento
Did you know Ford originated the "3rd member" concept with their early rear axles. The ring $ pinion were in a doughnut shaped carrier, with the actual axle tubes bolted onto both sides. The tubes were the 1st, and second, while the gears were the "Third member".
Old 09/29/17, 06:09 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
The bee's knees right here ladies!
Page generated in 0.31992 seconds with 54 queries
