Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 08/08/12, 01:39 PM   #1
Gravel Maker
Gravel Maker's Avatar
Quick with a Laser!
Sacramento
Smile Ruffstuff 3 Link Kit!
We have here everything to create a 3 link suspension, front or rear, and not low end stuff just to be cheap either! The kit is wrapped around 6 of our 1.25" Heat & Cryo Treated Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs and another set of the same in 7/8" for the Panhard. We add our Chassis Link Brackets, a 10 degree Adjustable Axle Link Tower, a 10 degree Adjustable Frame bracket for the 3rd link, the Axle Lower Link brackets. We finish the Kit off with the Panhard setup, an Axle Offset panhard Bracket & the Frame panhard (Inside or Outside).
We do not include the tubing because you will save alot of money buying your tube locally when you add the shipping cost of the tube, 2" x .25" wall DOM weighs over 4.5lbs a foot! If you need to change anything give us a call and we can mix & match til its right for you! We do have DOM as an option but always price it locally first...
These are $573 and $23 to ship, sound fair to you?
Dan Fredrickson 916.600.1945
www.ruffstuffspecialties.com
Your Fab Parts Specialist
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old 08/09/12, 02:15 AM   #2
Jwredneck
Jwredneck's Avatar
Fife,Wa
Dan from experience I found the 10 degree is too tight to fit in our narrow Bronco frames. I used your 3 link kit, but had to use zero degree for the upper link. Maybe add a zero degree option when ordering?
"Here, hold my beer...I got an idea!"
Jwredneck is offline   Reply With Quote
Old 08/10/12, 09:12 PM   #3
Gravel Maker
Quick with a Laser!
Sacramento
We just added one to the site, I will get Garett to add it as an option...Thanks
Old 01/13/13, 07:14 PM   #4
Gravel Maker
Quick with a Laser!
Sacramento
Time to finish your build with one of these!
Old 01/21/13, 11:16 AM   #5
Gravel Maker
Quick with a Laser!
Sacramento
Hope everyone had a great weekend
Old 02/19/13, 08:08 PM   #6
Gravel Maker
Quick with a Laser!
Sacramento
3 Link your rig! You know you want to!
Old 02/21/13, 09:01 PM   #7
Gravel Maker
Quick with a Laser!
Sacramento
For the right amount of articulation, a 3 link is the way to go!
Old 03/05/13, 11:40 AM   #8
Gravel Maker
Quick with a Laser!
Sacramento
All in one kit at a price you can afford!
Old 04/02/13, 11:58 AM   #9
Gravel Maker
Quick with a Laser!
Sacramento
A 3 link is way better than a no link
Old 04/12/13, 11:21 AM   #10
Gravel Maker
Quick with a Laser!
Sacramento
Take to the trails with the right amount of flex!
Old 04/27/13, 10:14 AM   #11
Gravel Maker
Quick with a Laser!
Sacramento
Link it up!
Old 05/31/13, 10:59 AM   #12
Gravel Maker
Quick with a Laser!
Sacramento
You can't lose with a 3 link!
Old 06/05/13, 02:04 PM   #13
Gravel Maker
Quick with a Laser!
Sacramento
Solve your flex problem with a 3 link!
Old 06/09/13, 06:02 PM   #14
Gravel Maker
Quick with a Laser!
Sacramento
You can't go wrong with a 3 link!
Old 07/10/13, 12:27 PM   #15
Gravel Maker
Quick with a Laser!
Sacramento
When all else fails, think RUFFSTUFF!
Page generated in 0.33214 seconds with 58 queries
