Tito
CB Fire Starter
Dont have to sell but would like to clear out some stuff and this is a big item. Currently attached to a dolly, dolly can go with for $100
Can deliver within 250 miles for fuel costs.
Tub only, no doors, tailgate top or fenders - $1200
I do have doors if desired as well, just not included in this sale, can get pics for you.
I have a real nice tub for sale, only surface rust in the floors and a few spots here and there, no rot except for on inner fender (see pic) and a single strange spot on a door post (does not affect door hangers).
Rear fenders have been cut,
Cowl area has been modified on pass side to eliminate air box, could be cut back out I am sure if you wanted.
Stainless windshield hinge already installed
Extra spray paint is from covering areas that were bare metal to reduce any moisture exposure, half the tub was stripped to metal.
There was a 3 speed on the floor, patch panel was installed over hole, a few other holes in floor from seats but nothing a few minutes with a welder and grinder wouldnt take care of.
Rockers are solid, driver side had 2 dings that were pulled out, very little bondo in those spots. Pass side has a small ding, no bondo.
Quarter seams are healthy
Does not seem to be any hip spreading in the rear, included a pic with a tailgate on to show.
Hangs doors well.
Will need a couple of the bolt holes where the front fenders attach drilled out and retapped (had to cut bolt heads off to remove fenders).
Front clip is a bit wavy but hangs fenders fine, was hit in on one side and banged out. (looks kinda like reynolds wrap).
Hangs doors well.
