Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 09/13/10, 07:44 PM   #31
cs_88
cs_88's Avatar
Shall not be infringed.
Riverton, Utah
Just got my cluster back from Kevin and as you can see he did an awesome job. My cluster wasn't too bad but Kevin really made it look nice, and he only had it a few days.
Good as new.
Click image for larger version
ID:	179385   Click image for larger version
'74 U151 Bronco Explorer, WH 2.5"SL, C4, 33's, 4.11's, Aussie locker up front, factory LS in back, 351W Edelbrock intake, Summit 600 CFM carb, stock hood no BL no problem, Flowmaster 50's.
'99 F250 V10 ridin' on 35's. '97 Explorer 5.0
cs_88 is offline   Reply With Quote
Old 09/15/10, 08:55 PM   #32
fatboy4211
fatboy4211's Avatar
Ennis, TX
kevin
you should see mine by friday. can you send me a before/aft pic. set odometer to 0000
thx
"They are so smart...That they are stupid." Still true today DAD!
fatboy4211 is offline   Reply With Quote
Old 09/15/10, 10:01 PM   #33
fallingdown
fallingdown's Avatar
Herriman, Utah
Originally Posted by fatboy4211 View Post
kevin
thx
I will make sure I take some pictures and set the odometer to 00000.
Thank you,
Kevin
For more information on gauge restoration: classygauges.com
fallingdown is offline   Reply With Quote
Old 09/15/10, 10:15 PM   #34
Izzy
Izzy's Avatar
More fun than you can throw a stick at...
Prosper
Man Kevin, your staying busy huh? Glad to see that and can't wait to see mine. I'm guessing it's 13,000 feet right now
'69 Red Beast:-5.0/EFI, 4r70w, 4.88s locked Dana 44, Ford 9, 3.5"sl 33" AT
CO Cabin Getaway
Izzy is offline   Reply With Quote
Old 09/15/10, 10:19 PM   #35
fallingdown
Herriman, Utah
Old 09/16/10, 05:54 AM   #36
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
nice job, have a partial one (apart already) would that work as well?
tasker is online now   Reply With Quote
Old 09/16/10, 06:09 AM   #37
fallingdown
Herriman, Utah
That's not a problem at all.
Old 09/17/10, 12:50 PM   #38
benderkevin
benderkevin's Avatar
Queen Creek
Hi Kevin,
I took my speedo/gauge cluster apart last night and saw that the round circular part that sits right above the odometer has been riding on the odometer and has rubbed the paint off of two of the number wheels and has worn down one end of the odometer "roll".
It also looks like the plastic gear is boggered up and two of the four cast head pins are broke. I'm assumung thats what allows it to lean and rub.
So my question to you is. What would it be to replace or rebuild this one.
The rool and gears are shot. I guess I could make something for the pins. And the head really needs to be oiled. It is really sticky.
No honey, thats always been on my bronco!!!
benderkevin is offline   Reply With Quote
Old 09/17/10, 01:20 PM   #39
fallingdown
Herriman, Utah
Originally Posted by benderkevin View Post
Hi Kevin,
I would have to take a look at your cluster to be sure, but it sounds like the head pins, odometer drum and gear just need replacing. There would be a small fee for the parts but the installation and labor are included in the $50.00 refurbishing fee. I would be happy to take care of it for you.
Thank you,
Kevin
Old 09/17/10, 01:22 PM   #40
benderkevin
Queen Creek
Thanks I'll call you.
Old 09/17/10, 02:20 PM   #41
Justafordguy
Justafordguy's Avatar
Tallahassee, Fl
Kevin,
The speedo on my 77 bounces wildly as I go down the road and also makes a jingling sound like a bell. Have you seen this before and can it be fixed easily?
Thanks,
77 Bronco, 302, 4bbl, Hei, C4, PS, PB, BCB-A/C, 33" KM2s, D44/Lock-Right - Chromo axles, 9"/Grizzly locker - Yukon axles, Tom Woods driveshafts, 2.5" sl, 1" bl, Bilstein shocks, 1 ton steering, JB-fab twin stick, D20,
2017 F350 CC LB KR FX4
2005 F250 CC FX4
2016 Edge Sport V6 EcoBoost AWD
Justafordguy is offline   Reply With Quote
Old 09/17/10, 02:35 PM   #42
fallingdown
Herriman, Utah
Originally Posted by Justafordguy View Post
Kevin,
Thanks,
Usually what you are describing is an indication that the balancing weight has come loose. Every time the weight spins around it hits the housing and sounds like a bell this is also more than likely what is causing the needle to bounce. This can be fixed but it requires disassembling the head unit. As long I can fix the balancing weight there would not be any extra charge.
Thank you,
Kevin
Old 09/17/10, 02:59 PM   #43
Justafordguy
Tallahassee, Fl
Thank you,
Kevin
Thanks Kevin,
I'll PM you later to get your address.
2005 F250 CC FX4
Old 09/17/10, 03:08 PM   #44
fallingdown
Herriman, Utah
Thanks Kevin,
Great, I look forward to it.
Old 09/17/10, 04:34 PM   #45
fatboy4211
fatboy4211's Avatar
Ennis, TX
Kevin,
Thanks for keeping me posted.
GREAT COMMUNICATION!
cant wait for it to come back. thank goodness my eb has a 10 gal reserve tank!
fatboy4211
Page generated in 0.32595 seconds with 60 queries
