Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 09/04/10, 09:55 PM   #16
Dan74Bronc
Dan74Bronc's Avatar
Chandler, Az
Kevin, My speedo needle bounces about a 30mph swing when I drive it. Gets louder and faster the faster I go. I Replaced the speedo cable because I thought that was the prob. I was wrong, its the speedo.
Can this be fixed? All the gauges work but the paint could use some help.
BTW, ar you the same guy that used to be in Mesa or Tempe?
Dan
'74 Bronco Ranger, 351 FITech EFI, ZF 5 speed, 411's and 35's and A/C. Daily driver.
Dan74Bronc is offline   Reply With Quote
Old 09/04/10, 10:11 PM   #17
jasonv
Broncos Rule!
San Luis Obispo, CA
I can one up a 30 MPH bounce, my bronco does (did, it's been in parts for several years) warp speed, it just goes around and around. Any ideas there?
Thanks,
Jason
jasonv is offline   Reply With Quote
Old 09/05/10, 02:36 AM   #18
fatboy4211
fatboy4211's Avatar
Ennis, TX
count me in. suggestions on best way to remove the cluster? i usually do things the hard way and break others things while im there. you should see the china cabinet!!
"They are so smart...That they are stupid." Still true today DAD!
fatboy4211 is offline   Reply With Quote
Old 09/05/10, 05:22 AM   #19
fallingdown
fallingdown's Avatar
Herriman, Utah
Dan
The bounce can be caused by several things. The most common problem is dirty, dry gears. I clean all of the gears and grease everything really well. The second thing that can cause that is a broken spedo gear. And no I have lived in utah almost all my life.
For more information on gauge restoration: classygauges.com
fallingdown is offline   Reply With Quote
Old 09/05/10, 05:27 AM   #20
fallingdown
Herriman, Utah
Thanks,
Jason
Jason,
Your problem sounds like you slipped a balancing weight. The spedo needle has a little weight that is always trying to pull it back to zero. When this weight gets out of place you find yourself in warp speed. I would be happy to fix it for you!
Kevin
Old 09/05/10, 05:39 AM   #21
fallingdown
Herriman, Utah
I remove the spedo as follows:
Undo the spedo cable from the back of the cluster.
Undo the 4 screws on the front holding the cluster into the dash.
Now pushing on the metal ring around the glass (not on the glass itself) push the cluster into the dash.
Angle the cluster face down.
Reach in through the open hole and pull the wires (it is a good idea to mark the wires so you know where everything goes later.
The bulb sockets just pull straight out (no twisting!!!!!!!!)
Slide the cluster out from under the dash.
Take your time and don't rush it, If you have any problems stop and give me a call 801-673-2933
Thank you,
Kevin
Old 09/05/10, 09:30 AM   #22
Izzy
Izzy's Avatar
More fun than you can throw a stick at...
Prosper
My gauge cluster is done and wow, what a difference. Great job Kevin, thanks so much. I can't wait to see it in person and in my dash.
Click image for larger version
Name:	Cluster Before.jpg
ID:	178516   Click image for larger version
Name:	Cluster After.jpg
Izzy is offline   Reply With Quote
Old 09/05/10, 10:30 AM   #23
abe_froman
abe_froman's Avatar
IT'S A DOUBLE RAINBOW
Knoxville, TN
Daaaaaaamn that looks good
abe_froman is offline   Reply With Quote
Old 09/05/10, 10:03 PM   #24
fallingdown
Herriman, Utah
Edit post (moved)
Old 09/06/10, 06:04 AM   #25
tasker
all knowing of nothing
tasker's Avatar
It's a jeep thing? you're all morons
The granite state
looks great, will be in touch in a few weeks
tasker is offline   Reply With Quote
Old 09/06/10, 06:38 AM   #26
John Marinan
Durango CO.
eBay: 1690johnm
Would you work on some 60s model Chris craft guages. There are very few people who do a nd they're usually backed up for months?
John Marinan is offline   Reply With Quote
Old 09/06/10, 09:00 AM   #27
fallingdown
Herriman, Utah
Absolutely but they are a bit more complicated than a Bronco so I can't give you a quote until I take a look at it. You are welcome to send it to me and I will check it out and we can go from there.
Kevin
Old 09/06/10, 09:41 AM   #28
fallingdown
Herriman, Utah
Old 09/07/10, 03:07 PM   #29
fallingdown
Herriman, Utah
Old 09/07/10, 03:42 PM   #30
fallingdown
Herriman, Utah
Post removed.
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
Copyright 1996-2019 All rights reserved. Privacy Statement
Page generated in 0.30901 seconds with 60 queries
