Go Back   ClassicBroncos.com Forums > 66-77 Ford Bronco > Bronco Chat > Vendor Forum & Current Mass Buys
Old 12/10/07, 03:22 PM   #1
rcmbronc
rcmbronc's Avatar
Tomah, WI.
Classic Bronco Tube Doors
I am now building some tube doors for the early Bronco. The doors are made from 1 3/4" x .095" tubing. My standard design uses the door post part of the original hinge along with the stock hing pin. The latch is a simple turn lever to catch the stock door post striker. A rubber cushion is supplied to eliminate rattling on the striker. The doors come in bare metal to be finished by the customer.
The cost of the doors is $230 plus shipping. I have a couple sets built right now and continue to build more. If there is demand for these I will make a list and build the doors for people according to who asked for a set first. I will not take any money until the doors are ready to be shipped. I will do my best to get them made as quick as I can for you, but this is not my main job so it may take a week to get them made if I dont have any in stock at the time.
I am no longer making them to fit lift off hinges. I can supply them without hinge mounts if you would want to do your own. PM me if you have any special requests and I will see if I can do it for you.
Feel free to contact me if you have any questions or need any additional info.
Thanks,
Rob Carlson
Click image for larger version
ID:	82887   Click image for larger version
ID:	82888   Click image for larger version
ID:	82889   Click image for larger version
ID:	82891   Click image for larger version
ID:	82892   Click image for larger version
76 351W, EFI, 4R70W, 4 1/2"WH lift with 11 pack rears, Cage arms, 1" BL, Tube Front End, 36 Iroks with Allied Beadlocks. 5.13 Spool Rear, Detroit Front W/Alloys, Hydroboost, Stonecrusher, Track Bar Riser, Corbeau Seats, Twin Stick, Slightly pre-dented.
rcmbronc is offline   Reply With Quote
Old 12/10/07, 03:56 PM   #2
Tito
CB Fire Starter
Tito's Avatar
The life of Tito is a path of mystery on the way to enlightenment.
Bakersfield, CA
What size are the lift offs for the wild child, I have the set from BroncoBob/All4Fun/Old Wild horses set of stainless.
Any chance of making some that would work with inserts?
Tito is offline   Reply With Quote
Old 12/10/07, 04:44 PM   #3
XT700
XT700's Avatar
F_RD BR_NC_ Would you like to buy a vowel?
Brownsville
What method of payment are you taking?
Thanks, Walt
1971-302, NP435, STAK, CORE 6 point cage, 3-1/2" Susp., 2" Body, 35" BFG A/T's, PS, Hydroboost DB.
XT700 is offline   Reply With Quote
Old 12/10/07, 07:38 PM   #4
Big_chuck73
Big_chuck73's Avatar
73 Bronco, goes by Chuck Norris
San Marcos, Texas
Those are sweet, I'm about a month out from needing them, do I have time?
Big_chuck73 is offline   Reply With Quote
Old 12/10/07, 07:40 PM   #5
rcmbronc
rcmbronc's Avatar
Tomah, WI.
The Wild Child are 5/16". I do not know what size the stainless ones are. Let me know what they are and maybe I can figure it out for you.
I would love to make them for inserts. I need to get a set soon and try it out. That I believe would look great.
Old 12/10/07, 07:45 PM   #6
rcmbronc
rcmbronc's Avatar
Tomah, WI.
(XT700)Payment can be either Pay-Pal or direct payment to me. Pay Pal is rcarlson@usemco.com. PM me if you want direct pay.
(big chuck73)A month would be fine. I have two sets ready right now and I am making more. Let me know if you definately want a set and I will hold a set for you.
Old 12/10/07, 07:48 PM   #7
Tito
CB Fire Starter
Tito's Avatar
Bakersfield, CA
Man, I'd give you a set if you could do it! Come on, who is local? We had a whole thread about tube doors for inserts a few months ago, they would be a serious hit! Only issue is bracing which I dont think would be bad, just tie it into the hinge bolts behind the insert and it would be secure.
Old 12/10/07, 07:54 PM   #8
rcmbronc
rcmbronc's Avatar
Tomah, WI.
Which inserts would be best to make them for. I may order a set and build them, but I need to know if the different styles would make a difference. It looks like the one-piece from Wild Horses are the best. Any advice on this?
Old 12/10/07, 07:59 PM   #9
onebadd73
onebadd73's Avatar
Semper Fi !
Moreno Valley, Ca.
PM sent.
1973 Bronco Sport, 4x4x2 PS, Hydro boost, 306, 670 T/A, 4R70w, NP205 twin sticked, 5.5" SL, 2" BL, Cage arms, 4 whl disc brks, FW HP44, ARB, 5.13's, FW 9 " Detroit Locker, 36" IROKS, Allied Beadlocks, Family Cage, Duff's 4 link kit, 102" wb
onebadd73 is offline   Reply With Quote
Old 12/10/07, 08:00 PM   #10
Tito
CB Fire Starter
Tito's Avatar
Bakersfield, CA
I think that all the inserts have the same shape and size to them, I can do a couple measurements, I have a set of Tom's 1 piece and a set of old school backless. I think that they would all measure out the same even the 1 piece ones. I can shoot you an idea if you want for the hinge plate.
Old 12/10/07, 08:04 PM   #11
rcmbronc
rcmbronc's Avatar
Tomah, WI.
Great, go ahead.
Old 12/10/07, 08:16 PM   #12
TN1776
Livermore, CA
Nice design. If you're still building them later on I'll be in touch. Tube doors have been on my list of things to build for a long time but why re-invent the wheel. I've got far too many other things to buy right now that I "need" that are taking precedence over the stuff I want.
TN1776 is offline   Reply With Quote
Old 12/10/07, 08:18 PM   #13
Tito
CB Fire Starter
Tito's Avatar
Bakersfield, CA
Here is my very crude representation...this is a see thu pic of course but helps show location, etc. I can clarify if needed.
Old 12/13/07, 02:55 PM   #14
Pokey71
Pokey71's Avatar
Im From Pirate
PBB
eBay: For-Be
count me in! whenh can they be avalible.. no stess on asap. its winter time but these would be cool for summer.
Tito.. for the door inserts, that would only be for looks, coorect?? i can see you hitting them one time and the fiberglass just cracking. then your out $300 fopr the door inserts
{o===o}
---> Go East Marines--->
Pokey71 is offline   Reply With Quote
Old 12/13/07, 03:34 PM   #15
Tito
CB Fire Starter
Tito's Avatar
Bakersfield, CA
For a little "sense" of security and an arm rest. Would also be easy to throw a skin on it for covered half doors too. I havent had a chance yet but I am wanting to make a set to work with my Crab Cage and open out through the insert (for actual protection).
Page generated in 0.31961 seconds with 59 queries
