HotWheels
Mark Troy said:forestguy Rodd, can you share the Napa part numbers?
thanks! ;D
here's the whole deal on the heter upgrade:
This is something that I have done and originally posted to the list about 6mo ago. Use the motor & cage from a 78 1/2 ton chevy pickup. Carquest part number #208971 (motor) & #209109 (cage). It is about a 30 min upgrade. You will need to cut the opening in the heater box larger. (I used a dremel tool). Use the cage as a guide. Then secure with some self tapping screws. The results are amazing. Cost under $40...
