I was kind of thinking thatI don't have pics but if you want to mount em up high cut the stock mount a few inches above the frame for extra support. I haven't put mine on yet but there were some posts about it before
Thank you, I did just install the duff long armsI have 3.5" suspension lift and duff long arms. When I went with Billstein 7100 series shocks, the 12" SB was a too short and the 14" short body works but I wish my mount was just a little bit higher. I mounted my F250 mounts before the long arms. The long arms moved the mount down a little so I changed from 12" to 14" shocks. If I would have done the mounts and arms at the same time, I would have put my 250 mounts higher.
So moral of the story. Mount them as high as you can while keeping them strong.
Thanks Dave, I searched and searched and didn't come up with much.
i would check you shock length , then measure the compressed and extended suspension mount them so they are not the bump stop or limiting strap
