sykanr0ng
- Aug 11, 2014
- 5,363
Oh yeah, I really like what you did with the speedo and the original style of font for the numbers and lettering. Looks like it will really blend in nicely and look like it came in the Bronco from the get go. Having said that, I have only one change that I would possibly make to it and this all depends on how it ends up looking in the end. The RPM Numbers get a bit LOST in the Silver ring around the speedometer arm and I was wondering if you could possibly maybe make the silver ring around the speedo arm a bit smaller so that the RPM numbers are not lost in the silver bezel. Even the way that it is I think it is a home run for the cluster. However, I think it could be even nicer if you could possibly give the Tachometer their own space where they will stand out and not possibly look like an afterthought. Hopefully that makes sense but I still really like the looks of the cluster. ;D
Thanks for your support Broncitis
Thanks for the input on the speedo, I will take that those changes into consideration. We only have limited space to work with, not much can move around in there. I like were you're going tho and we'll see what we can do!
Maybe an arc of black where the tach is?
So that it would be all one color.
